Question about Miele Washing Machines
Miele W698 - Programmes won't start, door won't open. There is power as the controller clciks and turns. Is it the door lock? I've taken it out and found it has 3 wires - Is there anyway to test to see if it is faulty? I don't want to buy a new lock and find it something more expensive
5 Suggested Answers
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin
Hey Cameron,
I saw you post today on another forum and did not have time to put my thoughts down before work. I agree not a clutch issue I had to :), you would be so lucky. I own the machine and can’t offer any more troubleshooting then what you have done, good job of that. Unfortunately the FAV6800AW/FAV9800AW SM doesn’t have a whole lot of support for troubleshooting beyond what you have done for this issue. I found more info from the MAH3000 manual on the technical operation of the motor controller (slightly different controller). Both machines use the same troubleshooting paths. Remove JP4 which is;
P1 Motor Control common
P2 Torque (to Motor Controller) see page 1-11 MAH3000
P3 Motor Control Tach (to control board input)
My WAG is replace the Motor Controller 1st, then Control board 2nd and a possible tach issue related to the motor. That’s enough WAGing,…. but with troubleshooting not a complete WAG :).
Take a look at pages 2-5 thru 2-11, I keyed in on page 2-11 in the MAH3000, it may give you some additional insight, I know we are dealing with different machine designs but I think the designs are close regarding motor controller, the motor and what the Control Board is doing and looking for with input from the Motor Controller. I wish the FAV6800AW/FAV9800AW SM gave this kind of detail for troubleshooting. There is a nice little troubleshooting table on 2-11.
I keyed in on this note;
The motor control monitors the signals and communicates this information to the machine control (control board). The purpose of this signal is to tell the motor when to energize each winding in the motor and to tell the machine control the actual motor speed.
Then this note;
Note: If the machine control board does not receive an input signal from the motor control/tachometer circuit (JP4 connector), the motor speed will rapidly accelerate for 5 seconds then shut down. The machine control will sense a "locked rotor" condition and the motor will stop. If the motor control does not receive an input signal from the motor, the motor will "****" for 5 seconds then shut down.
I don’t believe you have that condition. I have worked with a forum member who had an issue with the motor controller related to an Lr error, locked rotor error and replacing the Motor Controller fixed the issue. Form here I vote for an issue with the Motor Controller. Not having known good parts makes this a difficult job.
The control board is under warranty for 5 yrs from DOP, the Control Board is 2 yrs. Ebay is a good source 25001079
I would push Maytag CSV for both. I got them to send me a Control Board after discussing my troubleshooting and that I had a neighbor (me) that was a repair tech who would install. I also had to send them copy of my warranty not sure why they beeded that my machine was on file with them.
In your console you will find a Troubleshooting guide if you haven’t pulled it out already. It has the schematic for the machine which I find handy. If you want a soft PDF copy of the schematic I can e-mail you. Just ping me at dh1200s@yahoo.com. I use that for one-way contact, just respond back on this post if you ping me, I don’t check the account for month’s at a time.
With my limited knowledge I will try to help you. Good luck. Rich
Posted on Jun 20, 2009
Testimonial: "Awesome help and advice -- thank you to everyone!"
  • 6277 Answers
SOURCE: My Washer GLTF2940ES1 does not
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 29, 2011
Testimonial: "Thanks I have tried and cleaned out the filter pump and lines, still does not spin. Dave Perry"
  • 6277 Answers
SOURCE: i need a manual for a miele hydromatic w698
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
John C.
Posted on Jun 18, 2011
rickead1
  • 1998 Answers
SOURCE: door locked, won't turn on. won't reset
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Posted on Jul 04, 2011
Testimonial: "Good advice fast! Thank you so much for your time and expertise!"
The electronic door deactivation didn't work on my last load. I opened the door manually but cannot do another load until I deactivate the locking system. Can you help me please?
Believe you have activated child lock.turn off machine at socket then whilst holding the the start button turn on power and hold button in for three to five seconds.if you have a display...look for the key symbol...if it's there then child lock is activated..follow above procedure to cancel lock and key icon should disappear.
Jul 05, 2015 | Miele Washing Machines
I have a Mercedes c280 1999. the truck wont open there is no battery in the trunk. I,ve tried jumping it from under the hood. the key sword won,t work on the truck lock. when I connect the power to th
HI IVE GOT A CLK HAD THE SAME PROBLEM THE TROUBLE IS YOU DONT USE THE KEY AND THE LOCK SEIZES UP I HAD TO GO IN THROUGHT THE FIRST AID KIT AND CATCH THE CABLE THAT OPERATES THE REAR SEATS THEN CLIMB INTO THE BOOT AND THERE IS TWO BOLTS AT THE LOCK UNDO THEM THEN TAKE THE LOCK OUT AND REPLACE IT OR PERCIVERE WITH PLENTY WD 40 AND TIME
Sep 25, 2014 | Mercedes-Benz C-Class Cars & Trucks
How to change door seal on miele w698
Normally they're held on with 2 wire rings, 1 at the edge of the seal at the door opening and the other on the edge of the outer drum. Unplug your machine and remove the lid, this will help access and give you more light to work with. Remove the ring at the door opening first and pull seal from the lip. Access can now be made for the one at the drum. Do the same for the one on the drum.
When putting in new one reverse the procedure and start at the drum, make sure you have the seal the right way around, normally holes in bottom of seal for drainage. Thread the seal over the lip and then put ring on. Same process for the front. Put lid on and plug machine in and test for leaks.
Dec 29, 2012 | Washing Machines
Replacing door seal on w698 miele
Dec 29, 2012 | Miele W865 Front Load Washer
Electrolux dishwasher
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 05, 2012 | Electrolux 24 in. ESL4125 Dishwasher
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
I have a 2006 dodge caravan sxt. The pasenger power sliding door is not working. First we noticed that the power lock was not unlocking this door but if we manually unlocked it the power opener would work....
yes the door control module could be your problem or it could be you actuator and door motor, these rarely go bad at the same time, but it does happen, start with the door control module, you can usually get these at the junk yard for a reasonable price, hope this helps.
Aug 21, 2011 | 2006 Dodge Grand Caravan
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Washing Machines Logo
264 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
