Samsung HLM507W DLP TV
Hi Bobbyj,
Thanks very much for your advise on my power off/on issue. I had a feeling that it was either the lamp or the fan. Thanks for steering me in the right direction. Take care, Jeff
  • jeffjse Mar 28, 2008
    Bobbyj was right. I swapped out the lamp and the problem went away. The TV is now working great. Thanks very much !!!!!!!!!!!!!!!!!!
    Sergeant:
  • 395 Answers
Let me know how it turns out
Posted on Mar 25, 2008
Hi There... I have problem with my Infocus LP 130 The power is still ON, fan at the back is still working caused I can feel the air flow, but no light coming out from the lens. Can you please advise, what...
theres another fan next to the engine. all fans must work for the lamp to light. the colorwheel must be turning freely for the lamp to light. you can also take the top cover off and then slide the lamp out and then back in while watching to see if the connection on the lamp is pushing the female part on the lamp housing back instead of going into it. if it is, hold the female part in place with a driver or something while pushing the lamp into it.
Jun 01, 2010 | InFocus LP 130 Multimedia Projector
Lamp will not turn on. I have (2) PJ458D DLP projectors. I took the lamp out of the projector that is not working and placed it in the other projector and everything worked fine. When I press the on off...
It sounds like an internal problem. How long have you owned the projector? How long have you been experiencing this issue? Once I have more information I can assist you further.
Thanks,
Lee
Sep 23, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
Nec lt81 dlp projector
PLEASE SEE THE SPECS OF OLD LAMP AND NEW ONCE ARE THE SAME IF YES TRY CHECK THE POWER SUPPLY AND RATING OF THE SUPPLY. AND RESET SWITCH WITH REMOTE CONTROL
Feb 24, 2008 | NEC MultiSync MT1050 Multimedia Projector
I replaced the lamp and still have black screen
Hi
Thanks for using FixYa. To start with open the back off the unit and use compressed air to blow out all the dust from the components and avoid blowing it into the fan on the right as the dust will end up inside the lamp module. If still the issue is not resolved then check the Ballast which is the power source for the Lamp, as if that is not working it won’t let the lamp to work. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 17, 2010 | Panasonic PT-50DL54 50" Rear Projection...
When I turn the TV on it comes on for 1 min or so then turns off. I get the green blinking light by standby/power button. Then it comes back on....then off again.....then on. It just comes off and on...
Has the Lamp been replaced yet if not replace it pull backoff watch Fan to Lamp if it stops running while Lamp is trying to turn on Lamp will turn OFF FAN maybe defective. For Parts Call Encompass 1-800-638-3328 Clean out all dusty dirty Fans and around Lamp housing.
Oct 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a wd65100 when powered on i get steady orange light then status blinks red & green,unpluged for 1 hour tv is working but dark picture
Hi
This issue can be due to ballast fan, lamp or high temperature. However, to figure out this we'll need to check for the TV from inside(wiring & testing the components) or the other way is when the lights blink again then follow the procedure given. After you turn on the set, and get the red blinking lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 4 flashes, then 1 flash = 41.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Thanks
Rylee
Jul 28, 2009 | Televison & Video
PJ-TX100
sounds like what 80% of the projectors on this page are seeing... bad power supply or lamp ballast.
Jun 07, 2008 | Hitachi PJTX100 Multimedia Projector
Vizio fixed
glad to be of help
Apr 07, 2008 | Televison & Video
Benq pb6100, light bulb does not on, power ok
I fixed the exact same problem on my PB6200. Both back fans were not working, and the bulb would not turn on.
In my projector, the fan board had a bad capacitor. The fan board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard. The bad capacitor on my projector was coded C7302 on the schematics. It's a brown, 25v 470uf capacitor.
I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top. You can find pictures on the net.
Jan 22, 2008 | BenQ PB6100 Multimedia Projector
I need help to fix my Sony KDF E60A20
Check the thermal fuse part# 1-910-006-44. You can verify this by jumping the fuse and the lamp should come on (it is located under the lamp)
Aug 28, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
