Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Water does not drain out
After each wash there is about 1 cm of water left at the bottom of the interior of the dishwasher.
  • GE Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
There is always just a minimal amount of water in the bottom of a dishwasher so that the pump seal does not dry out causing water to run through the pump motor. Usually though it is not visible yet is is possible.
Excess water in the bottom of the tub post cycle are a sign of draining problems however this is a list of what it could be.
1. A partially clogged drain
2. The timer motor is not functioning properly
3. A broken or worn pump impeller
4. Clogged wash arm holes.
Here is what you need to do:
Check your entire drain system. Start at the final outlet and work your way backward to the motor pump connection on the dishwasher.
Suspected areas are.
a. The sink connection outlet is clogged (this can be inside a garbage disposal.
b. The air-gap is clogged in the very top part of the air-gap (Usually located on the back of the sink and is around 3 inches tall) Remove the cover, unscrew the top nut and check under the horse shoe bend inside the plastic top for obstructions. Clean as needed)
c. There is debris on top of the the motor pump housing blocking the inlet drain. (This would be inside the housing of the lower wash arm on the very bottom)
d. The motor pump outlet drain port is partially blocked. (only accessable from the motor pump exit hole after drain hose removal.)
A partially blocked inlet tub drain to the motor pump would also explain why the lower part of the dishes are not getting clean. Additionally you would have spotted dishes post cycle.
When the drain is partially blocked some models use the float level switch in the tub to control the advancement of the timer. If the water does not drain the motor pump continues to run and run and the cycle does not advance until the tub is drained and the float switch senses same. i.e extended cycle
Check under the float assy for debris.
One more thing to check is the lower wash arm holes for debris or obstructions. If the wash arm is retaining water it can drip out after a drain cycle and cause the puddling you noticed.
Thanks for using FixYa.
Kelly
Posted on Apr 29, 2010
How to make dishwasher drain? Water stands in bottom after washing. Also has buzzing sound!
Most likely you have something hard that got past the filter and got stuck in the drain pump, keeping the impeller from turning. Unplug the dishwasher. Siphon or vacuum out the water from the dishwasher. Remove the toe-kick panel(s) to get to the drain pump. Look carefully for a realease tab to press, then rotate the drain pump 1/8th to 1/4th turn to release it. Check for and clean out any foreigh objects, then re-assemble.
Sep 16, 2014 | Kenmore Dishwashers
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher has about 2" of
Is your drain line clear? It feeds into your sink drain and if there is any blockage it can prevent a good drain. Is the drain line as straight as possible? Make sure the bottom of the dishwasher is free of debris (food, paper from labels, etc; plastic pieces) . To be safe you can take a long handles brush and scrub around the center of the drain area to dislodge any materials. Also, a white vinegar rinse will sometimes help remove debris and clean the interior of the washer. 1/2 cup white vinegar in the tub and then begin the cycle. If none of these remedies help, it might be the pump or the timer.
Oct 28, 2010 | Vacuums
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Water hasn't drained and combination of lights notin troubleshoot
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Mar 29, 2010 | Smeg STX2 Dishwashers
After using my dishwasher,there is water left at
check all filters inside the dishwasher something is blocking the outlet hole,but also remember all dishwashers have about 1 inch of water left after a wash so check between washes.adrian;;;
Jan 20, 2010 | Dishwashers
Not cleaning fully - tablets left in bottom of unit - some of runners on bottom tray missing
Well first of all you can check the Water-inlet valve
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need replace it.
After then you can check the Drain valve,  that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Please post comments if you need more help or information..............
Good Luck!!
Thanks
Jan 07, 2010 | Zanussi 24 in. DE6544 Built-in Dishwasher
GE Max Dishwasher won't drain
I had the same problem with my GE Max model gsd6260k. I could hear it trying to drain and some small amounts of water going into the sink drain pipes but it never emptied it all there was aprox 1/2 inch of water that's 1.25 cm aprox for the metric lovers... lol
What i did was...Clean out all debris that was there.
There is a small basket (aka screen) just behind the bottom arms just a tad to the right i lifed it up enough to get a turkey baster into the opening (drain?). I coudn't seem to find the screws without taking all the bottom apart to get the basket out, as the water line going up the back to the center arms is there. Then i used the baster to remove water and i kept squeezing the air forcefully from the baster into the hole. This help, i don't know if it was a clog or what but i let the tub start to fill with water and then hit the start button again which makes it drain out. It was definately draining faster. when it finished there was no more water in the bottom of dishwasher.
Jan 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
664 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
