Question about Poulan 17" T&E Gas Trimmer
Manual I have a Poulon Weed Eater Model FLSST25 (featherlite 17 inch 2 cycle gas powered straight shaft string trimmer and I need a manual for it........what is the gas to oil ration?
    Scholar:
  • 71 Answers
Typically 32:1 to 40:1 for all these models. Use 35:1 and modern 2 cycle oil and you will be fine. :)
Posted on Sep 25, 2010
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/equipment/troybilt/TB22EC-trimmerTB22 EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
Why will My weed eater only run with the choke fully on and cant give throttle?
It sounds like the carb needs adjusted. Things can even happen to new weed eaters.
May 31, 2014 | Poulan P4500F 16-Inch Straight Shaft 25cc...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Weedeater FLSST25 FeatherLite 17-Inch 25cc 2-Cycle Gas Powered Straight Shaft String Trimmer won't start
remove the air filter and introduce a little fuel into the intake, attempt to start it with a few pulls, if it pops off a little you have a few system issue, if nothing happens remove the spark plug and observe whether it is damp, oily, black, light gray or nice and clean, if damp, you got too much gas, try drying it out and have a go again this time without any choke. If dry and clean or light grey, not enough fuel. check the plug for spark, making sure the ignition is on, if no spark, you have likely got a coil or switch problem, if you pull the plug and it is wet, and totally gray or brown and it sparks, you may have internal engine issues.
May 24, 2010 | Garden
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 17" T&E Gas Trimmer Logo
286 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
