Question about Logitech QuickCam Communicate STX Personal Web Camera
Logitech quick cam communicate stx on Vista - microphone not working
Hi I installed the logitech quick cam communicate stx on vista. It worked fine (using skype) for a few weeks and then the microphone ceased working. I uninstalled everything and started over from the beginning, but the microphone still doesn't work. Any ideas?
  • 9 more comments
  • Anonymous Mar 27, 2008
    have picture no sound
  • Anonymous Apr 02, 2008
    Hi I installed the logitech quick cam chat. It worked fine (using skype) for a few days and then the microphone ceased working. I uninstalled everything and started over from the beginning, but the microphone still doesn't work. Any ideas?
  • blubeldupp Apr 09, 2008
    I installed the Logitech QuickCam Communicate STX using the newest installer for Windows Vista from Logitech's website.Right after installation, the camera and in-built microphone both worked.
    After a restart of the system the next day, the video still works, the microphone doesn't.the QuickCam software will record video, but no sound, Skype complains there is no recording device, and I canät access the camera#sin-builtmicrophone by any means--the hardware assistant does not find it, the QuickCam software has the audio options disabled and has no 'test microphone' button or similar.
    In addition, WIndows itself complains about the device again when I start the computer. Windows wants me to install a driver for the camera. The driver is installed, but not though the hardware assistant -- the installation software from Logitech, qc1150.exe fromhttp://www.logitech.com/index.cfm/435/35... comes as an executable, not as a driver package I could feed to the hardware assistant.
    Again -- I have no way of troubleshooting the microphone, and it just ceased working from one day to the next.
    Logitech QuickCam Communicate STX under Windows Vista.
    Help greatly appreciated.
  • Anonymous Apr 13, 2008
    installed the quickcam communicate STX system-right off the system said no microphone found - tired everything still nothing
  • Fairchild Jun 10, 2008
    We set up quick cam and it worked ok a few times and then the mic and camera stopped working. We have just unistalled the software and reinstalled it and seem to be having the same problem. Please advise as to what we can do to correct this problem.
  • Anonymous Jul 16, 2008
    the skype message says that my webcam stx is not connected
  • NBEmoCoach Aug 05, 2008
    I have a great Logitech Pro 9000; which worked fine 2 months ago. Now it doesn't record videos ( I get Error Code 0x000001fe). The audio works fine, and I'm able to take snap shots. I've un-installed and re-installed about 10 times; tried soooo many things. I'm out of ideas.
  • Gilfres Oct 16, 2008
    I have a dual boot system Vista Home Premium 64 bits and Vista Enterprise 64 bits. I install the logitech quickcam communicate STX in the Vista Enterprise and I work find for several months until the last updated. After the last updated the microphone stop working. I un-install and re-install couple time with no lock. I called logitech technical support and after tried couple time following the instructions from logitech, the microphone is still not working. To check if was the bad hardware, I install the latest version 11.80 in the Vista Home Premium 64 and work fine.
    Openning the Volume Mixer under Recording Device the Logitech Microphone show there but I can't be selected. Looking the properties, the Level tab is blank. Boot in Vista Home, this Level tab show a slide to adjust the volume. Looking in the device manager shows the microphone is working propertly. I know that is a configuration problem, but I don't know what is.
  • carljdavis11 Oct 25, 2008
    I have exactly the same problem.. After a few weeks the mic on my stx quite working in Vista... Nothing seems to help..
  • 5567 Mar 29, 2009
    the microphone won't work,fix it now
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..is there a way to test the webcam, outside of an application like skype on your computer? did you check the audio settings?
  • 818 Answers
Why isn't the microphone on my camera working?
logitech quick cam communicate stx on Vista - micr - trnsp.gif Answer The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
This article covers how to configure a Logitech camera's audio and video settings to work with Skype 3.6 or above. trnsp.gif Answer This article applies to the following cameras:
QuickCam Orbit AF
QuickCam Pro for Notebooks
QuickCam Pro 9000
This article applies to the following platforms:
Windows Vista
Windows XP
This article applies to the following 3rd party application:
Skype™ 3.6 or above
To set up Skype for video please be sure that your Logitech webcam is connected and working. This can be verifed by launching your QuickCam software and checking for a video stream withinin the QuickCapture video window. Once the webcam functionality is verified, please close the QuickCam application and follow the steps below.
  1. Launch Skype™ and click on "logitech quick cam communicate stx on Vista - micr - 16439.jpg shown in the figure below
    Figlogitech quick cam communicate stx on Vista - micr - 16440.jpg>
  2. When you click on "Tools" you will see a drop down list
    Fig 2
  3. Click on "Options" at the bottom of the drop-down list
    Fig 3
  4. A new screen appears. Click on the left side of the pane under "Video Settinlogitech quick cam communicate stx on Vista - micr - 16443.jpg/> 16442.jpg
    Fig 4
  5. Under the "Slogitech quick cam communicate stx on Vista - micr - 16444.jpgcam" drop down, please choose your Logitech camera, then click the "Save" button.
    Fig 5
  6. Click on "Tools" as shown in Fig 6 to get your Logitech Audio setup. logitech quick cam communicate stx on Vista - micr - 16446.jpg16444.jpg
    Fig 6
  7. Wlogitech quick cam communicate stx on Vista - micr - 16447.jpglick on "Tools" you will see a drop down list
    Fig 7 logitech quick cam communicate stx on Vista - micr - 16448.jpgli>
  8. At the very bottom of the drop down list, please click on "Options"
    Fig 8
  9. When you click on "Options" you willogitech quick cam communicate stx on Vista - micr - 16449.jpgew screen
    Fig 9
  10. On this new screen click on the left side of the pane under "Audio Settings"
    Fig 10
  11. You will now have the option to select your Logitech camera's Microphone as your main Audio source. Under the "Microphone" drop down, select the Logitech Microphone, and click "Save"
    Fig 11
  12. You should now be ready to use your Logitech webcam and microphone in a Skype video call.
Posted on Apr 03, 2008
  • Logitech Master
  • 2,130 Answers
1st You download Webcam Driver.
Logitech quick cam
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Sep 15, 2013
Mine does that too!
i used it 2 days ago, and audio was working fine.
now theres no audio...and i cannot change the settings on my webcam! like the brightness, contrast, and when i do the audio wizard there is no audio thing detected!
HELP?!?!?!
I MIGHT TRY CALLING TECH SUPPORT.
Posted on Aug 07, 2009
    Scholar:
  • 80 Answers
Right click the volume icon in the bottom left corner,select recording devices,choose the device you want then click properties and make sure it is enabled. Also check your msn/yahoo settings and ensure that in the cam/audio settings that the box is checked next to "Allow other programes to use this device" otherwise it can become locked to a single programe
Posted on Oct 25, 2008
SOURCE:
I'm trying to configure my Vista voice recognition software. It does not recognize the microphone built into my Logitech webcam.
Are you sure the microphone built into the webcam working? Feel free to visit DigitalSupportTech for getting help.
Sep 01, 2009 | Logitech QuickCam Communicate STX Personal...
Vista
go here
http://www.logitech.com/index.cfm/435/225&cl=us,en
Sergio
Apr 13, 2008 | Logitech QuickCam Communicate STX Personal...
I've bought a logitech quickcam communicate STX. When I installed it first it worked fine. Someone unpluged it from the usb port and it wouldn't work. I re-installed the drivers and it was fine again but...
Feb 25, 2008 | Logitech Webcam
Built in Microphone doesn't work in AIM, Windows Live Messanger
You would be surprised at how many people don't realize that each application has it's own configuration screen.
It's not the end-users fault - like you said... the instructions could be a BIT more clear.
Feb 12, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam STX vista compatibility?
when you were installing the software did a taskbar pop up appear and tell you that hardware was found, and then proceeded to install the cam and inform you that the Logitech STX is now installed and ready for use? If not then the cam may need to be tried in another usb port as of yet it has not been recognised by windows. Also if this is being used on a laptop, sometimes there is not enough power amps being sent be the usb port to recognise, again trying a different port may solve that. If all else fails re install the software again, but make sure windows is allowing the cam to work, as sometimes there is an updater programme that works in conjunction with the cam to update drivers etc, this will probably be being dissalowed by either windows or your internet security programme and any part of the software that is being blocked may be stopping your cam also.
Jun 11, 2007 | Logitech QuickCam Communicate STX Personal...
Have you updated DirectX?, I'm not sure if Vista has DX9.0 or 9.0c, but you could try and update DirectX before you install the cam software. Also if the cam is usb, did you install the software "before" connecting the cam?, some people aren't aware that usb devices have to have the software installed first, before connecting the device.
Logitech QuickCam Communicate STX Personal Web Camera Logo
4,471 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
