Question about Kenmore 64802 Top Freezer Refrigerator
Refrigerator does not get cold
Refrigerator doen't get cold. Fans blow, but does not blow cold air. Freezer does not get cold also.
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 30, 2010
Freezer working fridge not
A refrigerator has one cooling unit and distributes cold air via fans and ducts. The freezer gets the bulk of the cooling and much less goes to the refrigerator box. If the freezer is cold your cooling unit is working, you must have either a bad fan or blockage between the cooling unit and the refrigerator box.
Dec 30, 2014 | Refrigerators
Fan motor run all time make bottom to freeze up
Which fan motor are you talking about? There are two fans, one that is under the cabinet that blows air over the condenser grill and compressor. The other one is normally in the freezer and is referred to as the evaporator fan, which forced cold air out of the freezer and into the refrigerator. This fan is normally controlled by the thermostat and coldness setting. So It could be either of these two that are keeping it running.
Jul 16, 2011 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Hotpoint side by side refrigerator. Freezer stopped blowing cold air while refrigerator side continued to cool. Freezer was totally thawed when I discovered problem but refrigerator side was still...
Hi
Check the freezer to ensure it isn't over loaded with food stuff; reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. Also check whether the unit needs defrosting or not. You should also check the coils on the rear of the refrigerator and make sure they are clean and dust free. If you still have problems after trying the above; you may need to call a repair service to come out and check the unit
Please check the bellow links to have a detailed idea related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
http://www.applianceaid.com/frig_notcold.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Hotpoint Refrigerators
Freezer working,refrigerator not cooling
Freezer fan may be seized. THe fan in the freezer blows cold air up into the fridge area. Fans can be replaced for about $20-$100 if you can do it yourself.
Dec 11, 2010 | Kenmore Refrigerators
Not getting cold enough to freeze, How to check Freon
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
After cleaning coils my refrigerator is still blowing warm air yet the freezer is cold what can I do myself to make the refrigerator cold?
There is a small fan which moves the cold air from the freezer to the refrigerator part. Make sure that this fan is working. If it is not turning, the cold air will not reach the refrigerator.
These fans are easily replaceable; however, you probably will have to remove the interior panels from the refrigerator to gain access.
Oct 09, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerator is not getting cold
Unplug it and let the freezer thaw for a day - there is likely ice buildup between the freezer and refrigertor side - which is not letting cold air get to the refrigerator side. Remove all food from the freezer and the refrigerator, and let the freezer totally defrost (allow 24 hours with the doors open) then plug it in and you should see a noticable difference. If that does not work, the fan could be bad. There are two fans, one in the back of the fridge down low on the outside, and one in the freezer behind a back panel on the inside down about half way. Try the defrosting first which should be the solution, and the easiest fix.
Aug 15, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator cold but not cold enough. freezer
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 06, 2009 | Refrigerators
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Jun 24, 2009 | LG LRTP1231W Top Freezer Refrigerator
Kenmore elite MOD.596.76533500
Hi, If the freezer is cold............ I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. The fans may be caked in ice and should run again but they may have burned up and need replaced. If it works good for a couple of days and problem returns, Replace the defrost timer. Hope this helps. kstfas
Sep 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 64802 Top Freezer Refrigerator Logo
157 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
