Usb drives Could anyone please tell me if the usb points in a pc. Are they powered by there own power supply as all of a sudden not one of them is working
USB hubs operate at 5V DC power, as do a lot of things on your motherboard do. They are able to transmit DC power to a device which makes it possible for items to be plugged straight into a USB port and not have an external power supply.It sounds as though the main connection between the USB points and the power supply has become broken, as a lot of USB points are connected in series to save space. Also, one point on the USB line could have possibly become grounded. A fewer simple measurements with an OHM reader may help in this situation.
Posted on Mar 25, 2008
Drive stopped responding -- problem with power supply or drive?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 05, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My WD external hard drive has suddenly stopped being recognised by my computer
Unplug the power supply from the hard drive, leave for 15 seconds.
Plug power supply back in.
Try another USB cable if that does not work.
Aug 08, 2011 | Western Digital Elements powered by WD 320...
I can not access my hard drive all of a sudden
Please check the USB cable and the USB connector at hard drive enclosure, and also if it uses external power supply, check if any power indicator turns on when you connect it to a power outlet.
Mar 03, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
Set up New PC Studio that is NPS then install USB drive
i have to install PC studio in my PC but when i tried it shown that my PC does not have NPS therefore it can not be installed. tell me how to install NPS.
May 30, 2010 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Is other power source needed to run this wheel besides USB on PC?
yes you will need another power adapter,usb will not be powerful enough to make it work hope this helps
My laptop will not accept a 320 g mass storage device. The message returned is that there is a power surge on the usb port. Can anyone help please?
Two things come to mind:
Disconnect the drive, run steps in this link
Reboot then try connecting it again
If no resolve, try a POWERED USB hub
Jan 26, 2010 | Dell Precision M60 Notebook
Flashing power light.
Have you tried a differnt usb cable if that dos not do it get back with me and I will walk you though checking it out
Jan 09, 2010 | Computers & Internet
1tb Western Digital hard drive stopped working suddenly, no light
If the hard drive does not even turn on, then check its power supply. Maybe the power supply went bad; it should be a standard 12V 3.5A power supply.
Even if the power supply is working, chances are good that your data are still there, because the unit not turning on means that the internal enclosure, not the disk electronics, got messed up. It's unlikely that BOTH enclosure electronics AND disk electronics went south together, unless you got a lightning strike at short distance (less than 60 feet, say). You'll need to open the enclosure, extract the drive and connect it to another compatible enclosure (most USB/eSATA enclosures with the same EIDE or SATA connector as your WD will do) in order to override the fritzed enclosure electronics and connect directly to the hard disk. Once you do, your data will be there. If the disk crashed last time it turned on, maybe you'll need to run disk checker and expect to lose a file or two.
On the other hand, if the drive does turn on when powered, and the PC "just" doesn't see it, chances are proportionately bad for your data: you'll need to send the disk to a data recovery service, which can be quite costly.
Nov 03, 2009 | Western Digital My Book Essential 1TB...
USP-porti doesn't find the external hard disk - occasionally
If it has been working and now does not not. If the system is ME or NTFS[XP /2000/VISTA] If the port check shows nothing untoward Then you must look to the the disc or its connection or power supply. So -if you can check out the power supply Is it self powered[internally of via a 'power brick'] or does it rely on USB power from the computer? If the latter- disable/unplug some other other USB devices. If it 'works on its own power' check that it is indeed running. Change the USB cable for another. Comeback if still in trouble
Sep 09, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to connect a IDE-to-USB cable to a 2.5 inch drive?
1) You will do no harm by reversing the connector, but the PC won't "see" the drive at that point (if your drive has an activity LED it will be permanently ON if the cable is reversed) 2) Most times the USB will have enough power to drive the HD all by itself, but if you are going through a hub that may not be the case. In that situation, plug the device directly into a USB port on the PC.
Apr 22, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
