Question about Uniden Cordless Phone
Have UNIDEN model XS1215+1NZ or Z068 cordless phone. If there is any slight noise in the room you can hardly hear the other person on the line. It is very sensitive to ambient noise and it seems to echo internal in the handset. We have tried changing the handsets around, reprogramming, checking the telecom line by technicians etc. but nothing we do seems to improve the quality of the handset operation. Any suggestions please ???
SOURCE: Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Posted on Oct 03, 2008
  • 82 Answers
SOURCE: Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Posted on Oct 14, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Posted on Oct 09, 2009
Uniden z068
Since you didn't specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Apr 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
What does t-coil mean on uniden dect 6.0
Here's the description from the Unident DECT1560 manual (the model I have).
https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/DECT1560om.pdf
Digital cordless phones generate magnetic signals that can cause noise on hearing aids equipped with a telecoil ("T" coil) feature. This phone includes a special "T-coil" mode that, when activated, reduces the magnetic noise generated by the handset.
Mar 12, 2012 | Uniden DECT 6.0 Cordless Phone ID
Can't hear the other side of the line. Uniden Elite
check the speaker of the phone it may damaged .welcome.
Jul 14, 2010 | Uniden Cordless Phone
Got very bad crackle in my lines.i did all i can got filters on for pc icolated phones(only got one phone ) Brought the uniden xdect 7015.Its hard to hear with all the noise in the lines.i did not have...
It could be the phone. It cound also be the line.You could either purchace or borrow another phone to see if the static is still there. If it is then itsa probabily a telephone company issue.
Jun 24, 2010 | Uniden Cordless Phone
I can hear but the person I am talking to cannot hear.
try cleaning the mic' without openning the phone -
from the outside by an old touth brush...
that will do the trick
if you can open the screws without any damage
than pull out the mic's cover
it is probebly full of moist
Jul 22, 2009 | Uniden DCX640 Cordless Expansion Handset
Uniden 3315 Frequency Problem
Your phone has Digital Enhanced Cordless Telecommunications (DECT), known as Digital European Cordless Telephone[1] until 1995, The digital filters will prevent interference from the bandwidths used by phones and wi-fi.
Your phone also incorporates dynamic channel allocation which switches frequencies when noise(static) is encountered.
Eventually your conversations take a wire route down the road. You are getting some "cross talk", an actual scientific term used to describe signal transmission from one line parallel to another by magnetic eddy currents. I would call the phone company and have them trace the problem.
May 13, 2009 | Uniden Lands Phones
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
Uniden phone
If this is a standard home phone, try another handset or handset cord. It it's wireless, it's the handset.
May 07, 2008 | Uniden DCT646-2 Cordless Phone
Cannot hear person calling
I am having the same problem with the same model phone! The line works with another phone but not with the GE cordless. If I call someone with the GE cordless they can hear it ring and hear me talking but I cannot hear them speaking. Silver Spring MD
Sep 06, 2007 | GE 21028GE3 Cordless Phone
Uniden Cordless Phone Logo
125 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
