Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishes not clean
Cloudy water accumulating on the bottom of dishwasher and dishes seem spotted and cloudy
  • 33 Answers
Four things use jet dry you have to with bosches use less soap. To much and it will stick also don't use cheap stuff preheat you water at the sink or else it can't get it to the 120 that it needs to be at best thing you can do watersoftener and then us even less soap you have hard water oh and don't prewash your dishes dishwashers now have sensers there has to be food in it. Follow these steps you will be fine
Posted on Apr 29, 2010
Our dishes are cloudy. It seems that the filter is dirty but I don't know how to remove it.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jun 18, 2011 | GE Monogram® ZBD6880NSS Stainless Steel...
Firgidaire dishwasher MODEL FDB641RJSB leaves cloudy residue on dishes. Top spin arm does not seem to be rotating,
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 01, 2011 | Frigidaire FDB125RH Dishwasher
Not sure what model but Frigidaire Dishwasher- the dishes are cloudy and gritty. The water gets hot, the cycle seems to be running normally, but even if I put clean dishes in, they come out cloudy and...
The problem is hard water leaving those spots. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 20, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Cloudy film on dishes
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem. It's located inside the dishwasher under the spray arm. Part 7 on this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170559&diagram_id=1332418#d1332418
Jun 07, 2010 | Maytag MDB9600A Jetclean II Built-in...
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
Cloudy Dishes - tried different detergents and not much change
Check the following to address this issue you are having..
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, I recommend a solution called Dishwasher Magic.
Jun 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
My Hotpoint Built in dishwasher mad#HDA3740G02SA won't drain
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
296 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
