Question about JVC GZ-MG130U Camcorder
Recording and copying
Last time I recorded and copied on a dvd using a JVC burner the audio was about 2 seconds out of sync with the video. First time this has happened. I was recording outside in 5 degree "C".
Any thoughs?
Jim
    Sergeant:
    Champion:
  • 435 Answers
probably writing error.
Was it playing w/ Sync on the cam ?
If so, try different burning software like Nero.
Posted on Mar 10, 2009
How do I copy(to DVD) my SVHS tapes using my JVC MV-40
It all depends on what kind of connections you are using. In most cases you set the dvd recorder to input 1. Then use the yellow,red & black or white out puts from the vhs player to hook up to the number 1 input on the dvd recorder. hit play on the vhs & record on the dvd recorder at the same time. Do not forget to put a blank dvd in the dvd recorder? also for the best copy set your dvd recorder to XP for a 1 hour recording for a 1 hour or longer recording set the dvd recorder speed to SP. You should have the dvd recorder hooked up to a Tv so you can monitor the recording progress. This should work out as long as the recording you are copying is not copy protected. Good luck.
Feb 07, 2015 | JVC Televison & Video
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
Hello, when dubbing from DV mini tape to HDD
well one solution may be the speed you are recording at. L.P. recording on a dvd often creates this problem. but usually it is when you copy dvd to dvd, not mini dvd to dvd
Never record more than 2 hrs on a disk
there are programs for a work around that reprocess the dvd vob file with adjustments for the sync.
could also be a hardware problem
is your mini dv long play source as well?
Cheers
Dave
May 18, 2010 | JVC SR-DVM700 DVD Recorder/HDD Recorder
I have a jvc everio share station cd-v3 dvd burner but when using
Try burning a copy that is recorded at a regular resolution. I think the hd 300 records at its highest setting in blue ray quality. Try something like SD mode. If yours has it. I have a jvc hd camera and its set up this way. Hope this helps.
May 20, 2009 | JVC Everio Share Station DVD Burner Burner
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Waiting for input signal
It's a protected video. The VRD-MC5 will not burn a VHS or input that has been protected.
Jan 09, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
Copy stored programs
If you have your unit hacked, then you can use tytool to copy the programs to your computer. This will only work for programs that are recorded once the unit is hacked. Do a search for the zipper for series2 dtivos.
Nov 23, 2007 | RCA DVR-40 DirecTV DTV Receiver / 35-Hours...
LG vs Lite On
both are just the same features just to write file from your hard drive. Maybe your point is you want the video from your VHS tapes will transfer to your hard drive. The only way to copy the video from your VHS is you need an external VHS player at the same time it will record the running video to a soft copy.
Please check this maybe this will be helpful http://www.allformp3.com/dvd-copy-software/convert-vhs-to-dvd.htm
Please rate me solve if you like my solution.
Best regards,
Philip
Oct 31, 2007 | Lite On (ldw811s) DVD±RW Burner
JVC GZ-MG130U Camcorder Logo
111 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
