Question about Whirlpool GU2400XTP Built-in Dishwasher
My silverware basket keeps opening up . The wire closer does not want to stay closed
Replacement silverware tray
Best Dishwasher Replacement Baskets - Amazon.com
www.amazon.com/...Replacement-Baskets/.../2232353...
Amazon.com, Inc.2. GE WD28X265 Dishwasher Silverware Basket · 4.6 out of 5 ... Whirlpool 6-918873Silverware Basket · 4.7 out of 5 ... 4. Whirlpool 8531233 Silverware Basket.
Nov 24, 2015 | KitchenAid Architect? II S SERIES KUDS03FT...
Is there a replacement Silverware basket replacement for Frigidaire dishwasher model PLD4460REC2
Hey friend, thanks for your post!
I see you are looking for the silverware basket on your Frigidaire dishwasher, PLD4460REC2. The part number you need is 5304454326 I see that part is no longer available from the manufacturer. You may want to look online for the part to see if it available. Hope this information is helpful. -Matt
Sep 25, 2014 | Frigidaire Dishwashers
We opened the door, now door won't close. The closer rod is locked open
Turn the screw in the end of the shaft (on the door end) counterclockwise to release all the pressure.Once it closes or slams shut, use that screw to adjust the closing speed. Other problem could be the stay open lock (the metal piece that slides along the shaft) could be all the way out keeping the door from closing. If it is just push on the door a bit then slide the lock plate all the way back to the end of the shaft, and the door will close.
Dec 21, 2013 | Wright Products Tap-N-Go White Screen and...
I have 2 mintcraft hydraulic door closers and one of them will not close on its own when opened past a certain point, is there a way to fix this?
The problem you have is there is either something inside the closer keeping it from closing or the closer is worn out and has tightened up. You can take the closer off and see if you can get it to work without being attached to the door to determine what is causing the problem. Also if your door is in a windy area then that could cause it to stay open. If you can't figure out what's causing the problem then you can replace the closer with a new one. If i'm not mistaken they run somewhere between 10 to 20 dollars depending on where you go to buy one.
Feb 07, 2013 | Mintcraft Black Hydraulic Door Closer...
Rear window doesn't stay locked
you need to move the latch closer together...
Nov 12, 2012 | 1996 Jeep Cherokee
DGB-550BK Filter basket won't stay shut when either brewing ground coffee or grinding beans.. With the ground; the basket pops open mid brew and makes a mess everywhere. When grinding beans, I've noticed...
Not a solution but...
Many folks have reported this, the latching mechanism wears out eventually.
We had the problem but discovered that the door on the basket wasn't getting completely closed. Now I make sure it's closed and haven't had any problem since.
Hope this solves your issue - if not, keep an eye on yard sales, we picked up two at different times for $5 and now have parts to swap out - not much help for a failed latch though.
Glad I never paid full price for it, even though it's a fairly good grinder/brewer.
Jan 19, 2010 | Cuisinart DGB-550BK
Soap door will not open
Chaney,
Make sure there is nothing in the way of the soap door when you close the dishwasher.
Close the dishwasher door slowly and look down in side with a flashlight, are any of the rack brackets or silverware basket directly in front of the dispenser door.
Take a look and let me know.
Regards.
Jul 21, 2009 | Frigidaire Dishwashers
The soap dispenser door will not open - I have been putting the tablets/ in the silverware basket for now but the dishes are not always coming out the cleanest. I think this is because the soap is being...
I believe this can happen if the unit is still engaged in a cleaning mode previously set. Try to close it and run a cleaning mode and then cancel that mode.
Apr 12, 2009 | Maytag MDB6000 Dishwasher
Deep fryer
If the lid will not stay open, there should be a small spring in the hinge. I am not sure of your model, But some have a safety interlock that will not allow operation with the lid open. These usually have a feature of raising and lowering the basket with the lid closed like some chemistry experiment!
What's wrong with a manual wire basket?
If the spring is not fitted correctly, or missing, it's fiddly but not impossible to replace.
Oct 28, 2008 | Kitchen Appliances - Others
Melting dishwasher basket
I need to know what make and model to tell you if anything can be done.
Feb 11, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
