Question about Whirlpool Duet GHW9150P Front Load Washer
Code F02 is lighting up, but the drain not pluged
Code F02 is lighting up, but the drain hose is not pluged.
  • 311 Answers
I would make sure that your using HE detergent. The FO2 error code can occur from a suds lock caused to too much detergent or not using high efficiency soap. If you are using HE soap then the problem is going to be in your drain pump. Its fairly easy to clean just google a how to on clearing the pump. Theres also some how's in the "tips" section on this webside. Hope this helps _MJ_
Posted on Apr 29, 2010
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
It is FO 2 its happpend twice no papper work for it?
Hello there and thank you for choosing fixya
Depending upon the type of washing machine, you may notice an "F21" or "F02" error code. An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Please feel free to post me a comment back if you need help with the dissasembly of this ok?
best regards Mike
Mar 28, 2011 | Washing Machines
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F02 at end of cycle. There is no kink or blockage in hoses or drain
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.****
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
Error code f02 comes up
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We are getting an F02 reading. The hoses are
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. Check the drain hose and make sure it is not plugged or kinked. Check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. If the above does not correct the problem, replace the pump.
Jan 06, 2010 | Kenmore Elite 45986 Front Load Washer
F02 Drain problem The drain hose has been checked, it's ok . Keeps showing F02 code. What's wrong?
HI There
Try this and let me know how that goes.
F/02 Long Drain
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank you for writing to fix ya.
Best regards Richard
Dec 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It quits on the drain cycle and a error code f02 appears
Error F02 code means Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed. Solutions: Press PAUSE/CANCEL twice to clear the display.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin out water, shows F02, already checked the hose for kinks and/or clogs?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
