Question about Sony Cyber-Shot DSC-L1 Digital Camera
Error Message Hello! Every time I turn My Sony camera on it starts beeping and and giving me the error message "Turn the power off and on again." I've tried turning it off and back on, along with taking the battery out and putting it back in and even pressing the reset button and I'm still continuing to get the same error message. Any ideas on what I can try next?
  • aviray21 Apr 01, 2008
    I too have the problem of the camera beeping when I turn it on..."turn the power off and on"...how do i fix this problem.
  • iamnat_211 Jun 27, 2008
    E:91:01
I have the same problem
Posted on Oct 19, 2008
  • 104 Answers
Hi, this err.related to ur lens.mechanical stuckup or dislocated this is repairable
Posted on Mar 25, 2008
Hello, I have a broblem with my super steadyshot, i get an error message:turn the power off and on again,,, help me plz
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Apr 19, 2011 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
As soon as i turn it on it beeps and says turn the power off and on again the lens wont move in and out
I'm sorry that the camera display the eror: turn the power off and on again. If turning the power on and off again does not resolve the error message, try doing a power reset. Refer the URL for the information to reset a Cyber-shot® digital still camera back to original factory settings:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C265373
If the issue is still unresolved, service may be required.
Jan 04, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
When camera is turned on the lens opens and closes several times and then an error message appears: "Turn the power off and on again." When this is done, the camera does the same thing - lens opens and...
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 20, 2010 | Sony Battery (844986068551) for CyberShot...
Camera turns on, lens cyles (in and out) 3 times, then camera displays a message "Turn the power off and on again" superimposed on the display. Image is not in focus and camera will not take picture, just...
This is lens mechanism problem and lens assembly will be replaced to fix the issue.
Lens tries to correct its mechanical error three times then gives up and you see turn power off and on again display in lcd. If camera is under warranty, please call Sony to get it fixed or take camera to local camera repair shop if its out of warranty.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Error message, cant take pictures
Camera needs to be serviced. This is a common problem with sony cameras. If you have any knowledge of electronic, you could take apart and clean and lube lens. If not sony will fix for a fee, go to the sony web site, they offer a repair service. This happened to mine, it cost $95 plus shipping costs to repair. Now it works great, for how long who knows.
Jul 17, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Error C:13:10, displays ''access'', ''turn the power off and on agai
Lens jams can happen without dropping the camera. The lens motor is bad, or a grain of sand has got stuck in one of the lens cogs. Either way will need lens repair/replacement.
Nov 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Error message on display
Had the same problem, turn on camera wait until power up is complete and turn it off again. Give lens area a firm hit and turn camera on error should be fixed. try several times as it may not work first time. This worked for me hope it helps
Oct 16, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-Shot DSC-L1 Digital Camera Logo
142 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
