Question about Refrigerators
My lightbulb in my fridge won't go on
Hi, my lightbulb burned out in my old-style maytag refrigerator, i replaced it (with a 60 watt bulb) but the light won't go on, and the fridge is still blowing cold air, so i know that the fuse isn't blown, can you help me?
  • 999 Answers
Check the tab in the center of he bulb socket. Unplug the frig first and gently pull it up a little. You should be using a 40 watt appliance bulb not a 60. If the tab is not the problem you may need a new switch.
Eric
Posted on Apr 30, 2010
Where do I buy a lightbulb for the Nostalgia model?
It is just a small spot light. Take the old bulb to your local hardware store. They will have a replacement.
Mar 08, 2015 | Nostalgia Electrics Helman Group CCP-509...
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Why do my lightbulbs keep blowing
Hi there and welcome to fixya,
There are a lot of attributes to that.. it could be unregulated voltage or a poor bulb quality. I recommend buying a higher quality bulb or better, replace it with the same type (fridge bulb).. some bulbs can't handle sudden temperature change inside the fridge that's why.
Hope this helps
Dec 28, 2010 | Refrigerators
Replace a lightbulb in a microwave
That's covered on page 24 of the owner's manual.
If you've misplaced yours, you can download it online here.
If you need to order a bulb or other part or accessory, visit here.
May 31, 2010 | Maytag MMV5207A Microwave Oven
Wanting to know what size lightbulb to replace in refridge this Galaxy is about 15 years old
Most likely a 40 watt appliance bulb.  You can get them at any hardware store.
Aug 25, 2009 | Refrigerators
Light socket burning out
Due to not screwing bulbs in tight enough , and/or too high wattage lite bulbs ( 40 watt recommended ) .
Jul 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Blown bulb in Maytag Neptune Drying center in tumbler section
1-800-688-9900 OR WWW.MAYTAG.COM, THIS SHOULD HELP YOU OUT.
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a Hygena Built in fridge freezer and the freezer is defrosting and the fridge is not coming
hi try this On the refrigerator door jamb, locate a small push-button switch. This component operates the light inside the refrigerator. If the switch is malfunctioning, the light in the unit may stay on, and the heat from the lightbulb can cause cooling trouble in the box.
Step 1: Check the bulb to see if it is burned out. If not, depress the push button on the door switch.
Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale
Step 3: Clip one probe of the VOM to each terminal of the switch and press the push button. The meter should read zero. If the needle on the scale moves above zero, replace the switch with a new one of the same type.
Step 4: Connect the new switch the same way the old one was connected.
Sep 13, 2008 | Refrigerators
Refrigerator (Whirlpool) increase in electricity usage
very doubtfull fridge fault would double elec consumption. look at rating plate and see how many watts then equate this to light bulbs. average light bulb is 60-100 watts (uk). does circuit breaker you turned off only control the fridge?
Mar 21, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
