Question about Dryers
Hi, I have Hunter fans throughout the house. This particular one has a light kit.. We thought the light burnt out and replaced the bulb. It still does not work.. There is a very faint flicker in the bulb. We replaced the old with a Brand New one. What are the likely sources of the problem and what is the potential fix? Thank you Dave
    President:
  • 1,619 Answers
The balast that controls the light is most likely out not giving good power supply to the bulb.
Posted on Apr 29, 2010
Testimonial: "This free advice was better than the paid advice I got from this site. I was connected with someone from South Africa who didnt help me much "
  • Jason Johnson Apr 29, 2010
    Sometimes extra information you give after reading your original problem helps us.
Have a Hunter model 28675 ceiling fan with two light fixture. Turned lights on, heard a pop. One of the bulbs blew, turned black. Now the lights will not work with new bulbs.
Is the fan and light kit equipped with a wireless remote control? If so a short in the light fixture sockets will cause a backfeed into the electronic circuit boards of the remote controls receiver and burn it out. If you have a voltage tester or pigtail with a light bulb remove the screws for the light kit and disconnect the two wires from it. Connect your voltmeter or pigtail to the two wires that were connected to the light kit. Have someone turn on switch for light or push light button on remote and see if you are getting power, If you are then problem is in light kit. If no power is present then receiver for remote is burnt out. Depending on the fan receiver can be built into the fan or located inside the top canopy and can be easily replaced. As per the light kit having a watt regulator it is possible that was installed to prevent overheating of the sockets by the manufacturer. That can also have blown out causing no power to get to the bulbs. If you have power at the wires that connect to the light kit then the watt regulator is defective. You can bypass the part but you must insure that you do not install bulbs that are of a higher wattage then what the fixture is rated for. Or you can order a replacement from Hunter. Good luck.
Jan 27, 2018 | Electrical Supplies
Can I replace the VEB82122 ballast on my hunter fan with a "regular" light kit?
Use an 8 inch Circline T9 daylight LED and directly relamp fluorescent FC8T9 bulb without rewiring
Feb 18, 2017 | Hunter Dryers
Hunter fan Model 20722 lights flash several times when turned on?
Not the capacitor. If this fan has a remote make sure it's set for incandescent bulb & not CFL bulb. Should be where you install the battery. Also, make sure you're using the correct wattage as it might have a limiter in the fan.
Dec 05, 2015 | Hunter Dryers
Hunter-ceiling-fan light wont work
Make sure your contact in the socket is touching the bulb.
Mar 27, 2014 | Dryers
Has 4 bulb capacity and for a long time only 2 of the 4 would work. The other two would blow out. Last week the replacement bulbs blew out as soon as we flipped the swith then there was a burn smell. ...
WAIT! Are you SURE the 98480-02 is burnt? This is part of the FAN circuits and NOT your lights?
But wait again! Here is ANOTHER Link complaining about LIGHTS and this FAN module (who knew!):
98480X Hunter Fan Control Switch Repair
(I know, their photo does NOT match your part)
IF it is burnt here is a replacement for under $9
https://www.lightingdirect.com/craftmade-4565uf-ceiling-fan-triple-capacitor/p3035848?uid=3035848
It's proper name is: "Hunter Fan model 98480X control switch".
Anthony
Sep 22, 2017 | Hunter Ceiling Fan Light Switch Control
My Hunter fan with light kit has a problem, again. The remote control works for the fan but not for the lights. One bulb burned out. Then the remote stopped working. Replacing the burnt out bulb did not...
this sounds like the remote in the fan went out the diod will burn out and cause this issue if you go in the fan by the breaker box and see the board you will see a burnt out diod you just need to replace the remote at lowes there about 45dollars good luck
Aug 04, 2011 | Hunter Ceiling Fan Remote Receiver...
Light won't work on hunter fan with wireless remote
probably your lights are blown replace them.good luck.
Feb 28, 2010 | Hunter 27187 Remote Control
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Hunter Fan has stopped accepting remote control signals
Hi, hunter fan replacement parts can be found on amazon, click here and take a look: Emerson Fans Moving Air In Style. I hope this helped you. have a nice day
Feb 10, 2008 | Oasis Hunter 54' Ceiling Fan
Dryers Logo
55 people viewed this question
Top Dryers Experts
