Question about Panasonic Viera TH-50PX80U Plasma TV
No power to tv
Try re-plugging and still doesn't work, the light doesn't even come on.
DOES THE RED LIGHT FLASH IF YES HOW MANY TIMES
Posted on Apr 29, 2010
My Veon 32" tv wont turn on
Help my veon tv power is on sound is work but the screen is black ..i dont know what to do ?
Apr 19, 2013 | Televison & Video
Spectroniq tv doesn't turn on, lights off.
The fuse is inside--power cord should go almost direct to it--beyond that if fuse good is power supply for the set.
Nov 06, 2012 | Televison & Video
The status light just blinks and tv doesn't come on
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 03, 2012 | Mitsubishi Cinema WD-82740 82-inch 1080p...
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
When I plug the tv it won't turn on nor does the
The red light is usually one of the first things that is powered by the power supply of the set. If even this is not working the place to start diagnosis is in the power supply. If you are not a qualified technician taking safety precautions then please refer the repair to a professional TV repair shop.
Jul 18, 2011 | Panasonic Televison & Video
I have a LG computer moniter and it just wont turn on i press the power button and the blue power light doesn't even stay on for a second
First Check your AC Plug if it is perfectly inserted. if inserted perfectly and still doesnt work, try using a working ac plug to check if your AC plug was the problem. If the monitor still doesnt work try checking you video card. Remove your video card and try cleaning the gold bars using a White Eraser. Insert the Video Card Back in and try running the computer. If it still doesnt work that means your monitor is the real problem.
Jun 28, 2011 | Computers & Internet
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Received a panasonic th-42pz80u from my father in law. He said it did not work. I plugged it up and it worked for a few hours. Now I get nothing when I plug it up. Is there anything I can do to restore...
Try using a different outlet, if that doesn't work see if you have another power cable that is the same power as the one on the T.V. and try that. If that doesn't work then there is probably a problem on the board near where the power plugs in. It could be fixed by a firmware update or it may need to actually be repaired.
May 04, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Green light come on when you push on button.It goes off after 4sec.TV will not come on
Try this... unplug the TV. Press and hold the power button for 30 seconds, repeat. Plug it back in and attempt to turn it on.
Unfortunately, if this doesn't work, then the TV will need to be repaired or replaced.
Apr 22, 2011 | Televison & Video
Panasonic Viera TH-50PX80U Plasma TV Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
