Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Paper jam message. I have changed the paper, two ribbons and reloaded many times but still get the paper jam message. The paper feeds about half way before it stops feeding and the paper jam message comes on. I have cleaned the rollers with alcohol. They were not dirty.This all happens only when receiving a fax. Sending a fax is no problem. Anything I can do short of having it repaired?
  • 1 more comment
  • rjacompany Apr 29, 2010
    When I am receiving a fax the paper feeds about half way before stopping. Then the paper jam message appears. I have cleared the paper from the feed mechanism. The paper is not torn or crumpled. There is no paper residue in the machine.
  • vvbb2 May 11, 2010
    Here is your solution
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
  • toiki1 May 11, 2010
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: i cant get anything to
Call your cell phone from the fax machine.
Call some fax numbers on a regular phone and listen for fax tones.
Do you have a DSL phone line?
Posted on Oct 14, 2008
fastxs
  • 6 Answers
SOURCE: We have a Brother FAX-1840c.
Hi
There must be some torn paper or something stuck in the Paper feed. You will need to ope the upper face portion by pulling it, and then look for papers/ dirt / pins there, you can either clean it by blowing air or use a blower, or if you can see the particle. Try feeding the paper, it should be ok.
Posted on Jan 27, 2009
jas247
  • 844 Answers
SOURCE: Using the ADF to Fax,
Welcome to FixYa.
Repeating paper jams are usually caused by torn paper(s) left inside the fax machine. This usually happens if you forced the paper out on its 1st or 2nd jam.
Solution.
  • Remove the drum unit and check for small pieces of torn paper or object that disrupts the flow of the paper.
  • Reinstall the drum unit.
  • Print a test page..
Thank you for using FixYa.
Have a great day.
Posted on Aug 01, 2011
SOURCE: We have a Brothers Intellifax
there are several fixes to this problem 1. replace pickup asembly 2. Clean the rubber pickup band are roller with a rubber cleaning compound (not alchohol0 alcohol dries out the rubber.
This is a common problem with printers and faxes, Paper has a tendency to leave a glass glaze on the pickup rollers therefore causing the paper to slip on the rollers are to be misfed thus causing a paper jam
Posted on Sep 23, 2011
Paper will not feed through printer part
cut the paper evenly with scissors before attempting to feed it into the paper entry port. If you just rip it, it will jam or fail to feed.
Nov 06, 2013 | Casio Office Equipment & Supplies
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Ink ribbon was chewed up in my son snap lab and resulted in paper jam. I cleared the jam and repaired the ink ribbon and it still is reading that error. How can I fix this?
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
You must open up the front where the roll goes. Lay the printer back, and look up top where the paper ejects. you should see some of the paper in the feed. Pull that out with a tweezers.
Beware. I sent my printer to Sony and they tried to get me for a new cutter and thermal head. Close to $500. I then realized the problem because it happened on another unit I own. I told them to ship it back unrepaired and I fixed it myself.
Hope this helps
Jan 14, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Cannot clear paper jam
Paper Jams in the Automatic Document Feeder
If you're loading legal-size paper, insert only 10 sheets at a time to prevent paper feeding problems.
If paper jams inside the ADF, clear the jam and reload the paper as follows:
1.
Open the ADF cover and remove any jammed paper.
Caution:
2.
Press OK, then select Yes and press OK to clear any messages on the display screen.
3.
Reload the paper. Make sure the corners of the paper are not bent, folded, or curled up.
Jan 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
I'm having trouble with the Javelin J330i printer. When trying to print cards it doesn't pull them through correctly and then gives an error that the ribbon is broken. I have tried resetting the printer,...
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
Jul 09, 2009 | Javelin Systems Inc Javelin Viper PC...
Paper Jam message
There are a couple of sensor flags in side the machine and also the document feeder area. Little black levers that flip and trip a sensor. Make sure they are all moving freely. There is one or two in the doc feed area. One inside the paper feed area. One or two in the ribbon area.
Apr 19, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
23 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
