Question about Keurig Elite B40 Coffee Maker
Serving size is too small on the largest size setting.
I think I am wasting coffee, because the serving size is too small. How can I increase the volume of the brewed coffee?
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart DCC 1150: coffee is not hot enough
Using the 1-4 cup setting will help, but that model does not have an actual heating element in the plate - definitely not the right model for someone who likes very hot coffee.
Posted on Jan 15, 2009
  • 10865 Answers
SOURCE: My Keurig coffee maker is not brewing the size cup
Hello. I recommend that you descale your machine. Here is how to do it: http://www.keurig.com/help/De-scaling_instructions.pdf?mscsid=27SCSLLH993M9P2RCE7EGD5S1AK660A1
Please reate my answer as very helpful. Thank you. Joe
Posted on Apr 23, 2010
tgmusicgirl
  • 92 Answers
SOURCE: will only brew small cup
Every level is a physical sensor in a clear plastic housing just above the main water heater...
when you select a size, the main pump starts to push water into the heater, and the hot water fills this plastic housing... there are about 7 stainless steel sensors that make contact with the water level... based on what you selected...
without knowing how long you had the unit and the type of water is used... etc.etc. you can try the obvious... run vinegar thru it and see if the unit starts working correctly. replace the water with vinegar and let the vinegar work for a few hours...
Otherwise you are relegated to opening up the unit and resetting the connections... which go intermittent and lose connectivity.
I have a discussion on this site about taking off the black shroud and opening up the panel that has all of the connections that unplug...
those get reseated, and that usually fixed it.....
Posted on May 06, 2010
SOURCE: I have a platinum Keurig coffee maker. I descale
Dear Rschles2,
I too own a Keurig Platinim.. I haven't a solution for your problem but I can tell you that your description of it is right on... I have had the same problem. Every month or two, my Keurig will decide I need a large cup rather than the size I chose. I've found no way to solve it... even unplugging the machine doesn't help. In the end, I remove my Kcup, and let the machine process a large cup of water. After that, it runs perfectly.... well, until the next time the Ghost appears.
maryann.
Posted on Jun 04, 2010
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
Mr coffee keurig problems
You have to select a serving size before pressing the brew now button.
Jan 06, 2014 | Coffee Makers & Espresso Machines
Enlarge text size
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text sizes largest to smallest and Full screen option
Increase the Font Size in Email
Email font size is easily controlled while composing messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size 8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text are even more difficult to read.
There are a few ways to quickly change font size for ease of reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100 percent.
Click "View" and cover "Zoom" to make a larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is "Medium," then click "Larger" or "Largest" to make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the wheel on the mouse.
The text will shrink as you roll in one direction, and grow bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display "100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text size.
Click the "Print" button to view the results on a hard copy.
Nov 13, 2013 | Computers & Internet
Large coffee button only puts out a little bit of coffee
keep holding the button down until the display says serving size. release the button when you are happy with the amount of product. next time it will fill to the same line. someone held the button down too long and programmed it to only dispense a small amount of coffee.
May 27, 2012 | Miele CVA615 Espresso Machine
I am pressing the button to give me the largest cup size. but it continues to give me the small cup size... please help
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 09, 2011 | Keurig Elite B40 Coffee Maker
The machine does not make a full serving. I will push the largest serving and the machine will produce 4 oz or so.
heatman101
May 09, 2011 | Keurig Elite B40 Coffee Maker
Print size too small
Assume you have IE 7, on the top right of the Browser, select Page/Text Size/Largest
Mar 22, 2009 | Computers & Internet
Small servings...
I purchased the new 'larger sized' portions of coffee (Maxwell house unfortunatley) and it seems to be a regular decent size cup, I know what you mean about the portion control w/ the espresso 'shooters', but there is no way I know of to adjust the output other than the manual override after the auto cycle.
Nov 22, 2007 | Braun Tassimo Espresso Machine/Coffee...
Keurig Elite B40 Coffee Maker Logo
337 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
