Question about Kenmore Oasis HE 27082 Top Load Washer
I would like to know if the kenmore oasis washing maching tub is to have liquid in it for balancing purposes
    President:
  • 1,937 Answers
See the following Whirlpool Service Manual for their Cabrio washer. The Kenmore Oasis is basically the same machine.
Yes it does have a balancing (actually 2) ring(s).
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Posted on Apr 30, 2010
KENMORE MODEL NUMBER 110.26912690 UNBALANCED DURING SPIN CYCLE
Open the lid. Remove clothes and drain tub. Reach in and give your tub a good shaking. You should hear a sloshing sound. If you don't hear sloshing your balance ring has somehow lost it's liquid and will need to be replaced.
Dec 21, 2012 | Kenmore Washing Machines
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
The machine gets out of balance during spin. Heavy load ,light load doesn't make any difference. When I stop the machine and rearrange clothes and then press start the water comes on and it goes thru...
To verify my suspicion, it will be necessary to pull the machine out from the wall and remove the lower panel which is normally only a half-dozen screws.
With the AC plug pulled and a good light, check the tub suspension which will be located at or near each corner and may be either sturdy springs or heavy rubber rings. They must all be attached to hold the tub centered. One of these has failed or at least come loose from its anchor.
Jul 06, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Does Kenmore Elite washer model 110.27092600 have water in bottom section of basket? I removed the one from mine because of balance problems and found the bottom molded plastic section of the basket has...
There is always water in the bottom to help keep the tub seals moist.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis top load always out of balance and bangs
First just to let you know, the oasis is very sensitive to the load level and water ratio if its too heavy the load has to be perfectly balanced inside the tub. Next check to see if any of the straps are broke. The next thing is that the newtator has tighted up all on its own so when it spins the newtator grabs the tub while it spins at high speed. I have never had to fix this but i know it is a common problem. I hope i helped a little. Good luck!
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Very loud spin cycle
your bearings i the tub have gone bad. It happens usually if you use powder soap. It doesnt dissolve all the way and gets into the bearings and ruins them. Sorry but this is a pretty expensive fix. When you get it fixed used liquid soap and it shouldnt happen again.
Nov 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
210 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
