Brother Intellifax2800 says Please Open Door. It won't print whats in memory. I open door and shut it then it sounds like it is printing but nothing comes out.
SOURCE: Problems sending and receiving faxes
then there is a sensor problem, here is the manual check troubleshooting section
http://www.retrevo.com/s/brother+2820+fax++manual
SOURCE: Brother HL 2040 won't print
Sounds like the toner cartridge is faulty. I would change the cartridge.
SOURCE: Brother Fax 2820 gives message: Back Door Open
It could be that a tab is broken off of the door that trips a switch. Cheat the switch with a small folded piece of paper.
SOURCE: ''Back door open, please close back door'' - back door is closed
This Error Is Reoccurring On All These Units Open Close Back Door Then Unplug For 30 Seconds And Then Plug It Back In. Check For Error.
The Brother Website Says To Check The Paper But Almost All Of These People Have Checked For Paper Problems And For Jams With No Result.
SOURCE: won't print; model 7820n; message:
first check and make sure that the back diir sensor is in place next if the paper is not going all the way in to the fuser section, you will have to remove the fuser and take it apart and remove paper in it, the paper is probally holding down the fuser sensor in side of it good luck brother sr, tech
