Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
I took off the back cap of a 300 mixer. then pulled out the motor brushes. put it back together and now it wont run. What am i missing?
  • 235 Answers
Hi, KIMAMABELL, While working on your mixer be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KSM90P, and select one of the files listed under Parts List (check to see it this matches your mixer model).
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder that includes #18, 20, 21, 22, 23, and 31 which is the brush holder and brush & Spring assembly respectively.
The brushes need to be installed so that they both seat correctly on the armature's commutator and it’s possible when you reinstalled them, one or both brushes were turned incorrectly.
The illustration below shows the correct orientation of the brushes and should allow you to reinstall them with confidence.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer for your future referennce.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! - hslincoln
Posted on Apr 30, 2010
My kitchen aid mixer produced sparks inside the engine housing. There was a burning smell.
burned motor, return to store if covered by warranty, or else have motor rewinded by expert motor technician
Mar 18, 2014 | KitchenAid Food Mixers
What are the two plastic screws in the side of a kitchen aid for ?
They are the motor brushes, you do not need to fiddle about with them. Take them out again, look at them, one corner is missing from the carbon block. Look in the hole with a torch, right at the bottom there is a small blocker in one corner, line up your missing corner on the brush with the blocker and put it back together. Stop fiddling about and make a cake.
Mar 15, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Ksm75wh mixer stopped running
Check carbon brushes under the black caps on the motor sides. They only go in ONE way so take care, there is a blocker in the square hole on one corner. Line it up with the missing brush corner. If it's not the brushes remove the back cover & check for broken wires. Do your checking with power unplugged.
Nov 28, 2013 | KitchenAid KSM75WH WhiteTilt-head Stand...
I took my kitchenAid stand mixer (md# KSM5PSAC) apart to replace the plastic gear inside of it. When I put it back together it would not start. I took it back apart took a good look at all the connections,...
You need to either re-time the speed control switch at the back or replace it. If it worked great before then it is just an adjustment to get it back to running correctly. YouTube viseo available for timing the switch
Aug 06, 2013 | KitchenAid K45SS Classic Stand Mixer
My mixer worked fine, I took it apart for a really good cleaning and now it won't work at all. Please show me how to take it apart & put it back together correctly.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model. Pay attention to the Motor Brushes, making sure
they are maiking contact with the Motor after re-assembly.
Aug 15, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
I just replaced worm wheel on my KitchenAid Stand Mixer. Power was working prior to worm wheel breakage. Mixer was running, but not spinning. Dismantled Mixer, and replaced worm wheel. Put back...
Check the carbon brushes, look inside the hole, it is keyed, the brushes only go in properly one way. Match the missing corner on the brush to the blocker inside the brush holder.
Sep 07, 2017 | KitchenAid Food Mixers
Took out/put back black brushs/motor wont turn on
Hi TUBEARS, from what you’re describing, I suspect that one or both of the brushes is (are) not seated properly when you reinstalled them. The brushes need to be installed so that they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the first file K45SSWH0.pdf (341.41 KB) listed under Parts List (1) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Feb 20, 2010 | KitchenAid K45SS Classic Stand Mixer
Speed and not running correctly on a ksm150
Hi JIM, Happy New Year! From the symptoms you describe of your sister’s mixer it appears there are a couple of issues that need to be addressed. Issue #1, when your sister found the loose governor counterweights that should have been a clue that the governor needs to be replaced. The counterweights should not come off the governor. From your description that you “put everything back together, the actual mixer runs (but a little too fast on slow)” is an indicator that although everything went back together, the governor is still not functioning properly, so it still should be replaced.
Issue #2, which concerned you more, was “the arcing that is constant on the actual contact points that turn the motor on and off.” The contact points you refer to are the mixer’s electric motor brushes, and although arcing continuously occurs (that’s why the mixer head gets hot during heavy usage) under normal operation, it may be time to inspect and replace the mixer’s brushes; the more worn the brushes, the greater the arcing, which makes it more noticeable while more heat is produced.
Before going too much further, be sure to have your Parts List Manual on hand, too. If you don’t have the original you can easily download a PDF version from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, KSM150P and select the file: KSM150PSWH0.pdf (773.44 KB) listed for your model that appears under Parts List (61). Check to see that this matches your sister’s mixer model.
Turn to pages 8 & 9, titled “Motor And Control Parts” which provide an exploded view for the disassembly and reassembly of the mixer’s motor and electrical control components. Locate Illus. Nos. 29 and 19, Governor Assembly and Carbon Brush, respectively. These are the parts that I would replace – one governor and two carbon brushes.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! – hslincoln
Dec 28, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Took apart, pull magnets from sides, now the thing
ECARRERO2004 - Those 'magnets' you removed from the sides of your mixer are the electric motor brushes that provide power to the commutator/armature assembly so your motor runs. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the commutaor. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start. I hope this helps - Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Nov 24, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Took brushes out to check and cannot get kitchenaid mixer to work.
Look at the brush from the side.. The surface that rides on the armature is curved> One leg is longer than the other leg. The long leg is the trailing and the short is the leading edge. Looking at the cooper end of the motor you can tell which way the motor rotates by the traces the brushes make. The leading edge will be on the clean side and the trailing edge is the side that is smeared black.on tthe copper. The long leg of the curve on each brush goes on the smearch side of those copper bars the brush rides on. Both brushes. Looking in the hole of the brush holders you will see what I mean. When you put the brushes in, you must make sure they are up against the copper and the springs are holding them down evenly.. You can lift the brush carefully and let it go to make sure it is working freely. Now, see if you can put an attachment on and turn it by hand. I'm not sure you will be able to so don't bend anything or hurt yourself.. Put the brush caps back on, remove the attachment and plug the mixer in.. Attachments off, fingers clear, turn it on. Does it run? If not, tap the mixer on its side with your hand.. Make sure the switch is on high. Tap it several times if need be. This is to straighten up the brushes to where the springs want them. When the motor starts turning, slight taps help. Keep it going until it picks up speed and let run for five minutes to seat the brushes. Let me know if it still won't run. I'll be watching for a comment from you.
Oct 26, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
571 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
