Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Hello, I have a Bosch Nexxt 500 and it is not ending the cycle not is it draining all the water. I am getting a E:13. The manual does not tell how to correct this. Please help...
SOURCE: My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Posted on Jul 19, 2008
farr64
  • 121 Answers
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Posted on Sep 14, 2009
57 varieties
  • 1653 Answers
SOURCE: Bosch Nexxt 700 won't drain water
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Good Luck.
Jul 12, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My Bosch front loading washer is flashing E:13 and won't open
Hi, i had an E-13 error code on my Bosch 500 series washer. The drain pump impeller was plugged. Access the drain impeller at the bottom front right corner. Just put a pen in the hole and turn the cover. Then you need to manually drain the washer. I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while. When you get it drained you can take the cap completely off. When I did I found a wipe in the impeller. I took it out and put it back together and the washer worked just as before.
Take care
Jun 13, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
The water won't drain from my Bosch Nexxt 500 Series Washer machine
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Sep 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Apr 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
398 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
