Question about HP Color Copier 155 Copier
HP 155 color copier "out of paper" but there is paper in tray
When we try to make a copy we get an error message of out of paper. It sounds like the rollers are not picking up the paper. We took out and cleaned the paper tray assembly, but it still doesn't grab the paper.
  • 2 more comments
  • hootholler Apr 30, 2010
    I have already tried the trouble-shooting steps in the user guide:
    removed the paper tray and cleaned the rollers. I ran a piece of sandpaper through to try and abrade the rollers so they would grab.
    That didn't help.
    It seems that the switch to lift the tray to grab a sheet of paper doesn't trigger. Can I buy a replacement switch (where?) instead of junking the whole copier? It was an expensive copier, well maintained, used lightly. Even though there are newer shinier models out now, when it works this copier does what I need it for, and it's paid for, along with an inventory of inks that fit only this model.
    I tried to find a service manual online. Do you know where I can find the repair manual given to the technicians?
    The previous expert sent me a page on paper jamming from the HP user manual. I already stated that it's not a paper jam issue: my problem is that the paper does not feed. I get an Out of Paper error message. I have tried every troubleshooting tip in the user manual. I need a technician's repair manual or advice from an HP technician who knows how to fix or replace the tray lift switch. Thank you.
  • hootholler May 01, 2010
    I think the switch or spring assemble needs to be replaced. Where can I get one and how do I install it?
    If I could get a hold of the technician's manuel and the piece, I might be able to replace it myself.
    My local repairman suggests throwing out the whole copier and getting a new one, but I'm sure it could be fixed with a 10¢ replacement spring.
    Thanks
    Julie
  • hootholler May 02, 2010
    I've had the copier for 4 years. The problems seems to be that the tray lift spring is not lifting the tray high enough for the paper feeder to grab. How do I fix or replace the spring? I don't want to dump a $2000 copies for a 10¢ part.
    thanks
  • 493 Answers
If you are using your copier for the first time, the scanner may be locked and you should unlock it as in the picture below.
Hope this helps.
HP 155 color copier
Posted on May 02, 2010
    Genius:
  • 1,040 Answers
Dear Hootholler,
In paper tray assembly, there is a spring type part or assembly, which helps to touch papers, to the roller... ensure that spring assembly is also working fine.... without this spring assembly roller will not be able to grab the paper....
Posted on Apr 30, 2010
    Genius:
  • HP Master
  • 1,354 Answers
    President:
  • 1,194 Answers
The possible solutions for your problem are:-
  • May be paper tray assembly is not properly installed, Remove & reinstall the paper tray assembly.
or
  • Mixed size or type of paper is install in input tray, load one type of paper or media IN tray at one time.
Good Luck & have a nice day.
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
HP 5510 OfficeJet - error message "Remove & check color cart"
check all areas for any paper jam, also check the feed roller in the paper trays if the roller are slick with paper dust, clean them and then reinstall the paper. Sounds like a paper sensor is not been cleared. then the error message, should go away on reboot.
Mar 16, 2009 | HP Compaq Evo Notebook N600c
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Paper feed issues
The problem is what you already stated, the rollers are too smooth so they are not grabbing the paper to feed it.
Try this : clean with alcohol and a clean cloth very well and make a copy it will probably make one or two then jam.
order the tires and replace. should cost you about $20
Nov 06, 2007 | Office Equipment & Supplies
HP Color Copier 155 Copier Logo
51 people viewed this question
Seeker5211
Seeker5211
