Question about Mitsubishi Televison & Video
I have a ws554131 I am getting error code 22. I am not getting 24v or -24v. All my fuses check good. Any suggestions?
  • Patrick McAlexander Apr 30, 2010
    Thank you for your response. I checked those fuses and they are good. I took the power supply board out completely with nothing attached and still have no voltage on -24 or +24. Diode gone bad or transformer maybe?
  • 10,515 Answers
The code 22 indicates Short-Circuit Protect. This can be caused by the 5 map pico fuses, F9A03 and F9A05. located on the power board. If either of these are open the problem will be in the convergence circuit. The convergence ICs have failed and will need to be replaced along with a few defective resistors. A TV repair company will normally charge about $350 for this repair if the ICs are the problem, less for the fuses. Convergence failure is a very common problem with this TV set. There could be other parts that are not within factory specs. The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test equipment to determine what parts that are no longer within specs. A small TV repair shop will many times be less expensive than a large repair facility.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 29, 2010
Hi , I have a Suzuki k8 1000, showing a C93 error, all lights ect come on, but it's not turning over...any suggestions?
Alana, C93 is the steering damper solenoid sensor. Why it is not starting is a different problem that may correct C93 code.
Not turning over, check battery condition and connections, fuses/relays, wiring and plugs, Test/check ignition switch and button, check/test solenoid/starter,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
K7 1000 SD error code or steering dampner code
2007 gsxr1000 C93 Error code
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
Mar 31, 2016 | Suzuki Cars & Trucks
Air compressor on 1988 cadillac deville will not turn on. Have installed new electronic control module and we think that has gone bad. Cannot locate a new one? Any suggestions
2 fuses under hood fuse box. makes sure there good. under the back seat there is a fuse and a relay. The fuse box cover will tell you where they are. If all fuses are good and the relay is good. Then you will need the control module located behind the trunk cover lining on the right side or the air pump located under the car next to the right rear wheel. My bet is on the air pump...
Jul 01, 2011 | Cadillac DeVille Cars & Trucks
My honeywell thermostat display is blank. I have changed the batteries, checked the circuit breaker with no luck. if you switch it from auto to off, the fan will go on but there still is no heat. Any...
could be either a fuse on the furnace circuit board, broken thermostat wire or an error code stored on furnace circuit board. look for a small viewing port on the furnace. look into it for any lights. if you have an error code it will blink out a number code. if so, look on the reverse side of the front panel near the wiring diagram for a diagnostic code. check circuit board for small glass fuse and make sure it is good. take thermostat wires at thermostat and jump w and r terminals together. if it works, bad thermostat. if not, bad wire or circuit board on furnace.
if I helped you, please rate my answer.
Jan 23, 2011 | Heating & Cooling
I am getting an error code "50 Service". I have had this before. Supposedly there is a part that gets hot and causes this. The solution suggested was to turn it off and let it cool down. I...
Hello
90% of the time this is caused by a burnt out quartz fusing lamp (Click here for information on how to test the fusing lamp). The DC controller does not see the fuser get up to operating temperature and produces the error message.
Replace the necessary parts, all of which are included in this repair kit (along with easy to follow directions).
Good Luck, and do rate the solution if got help
Dec 20, 2010 | HP LaserJet 4 plus Printer
Okay, I replaced my convergence chips because I was getting the 3D effect. It seemed to clear some of the picture up, but I am still bowing at the top and bottom of the screen. As well as it looks like the...
Sometimes these boards are not repairable at a local level. I know this very well. It is my suggestion to contact Union Electronics at 1 800 648 6657 and ask for Heather. Be sure you have the TV model# and your board #. You may purchase a refurbished board at a reasonable price and receive a few bucks on your old one. You will be pleased with the results. I have had to do this on many occasions! Also, there is a guarantee on this reworked board. I have had very, very good luck with these . Good luck and thanks for asking and show a few hands of support!
Nov 04, 2010 | Philips 60P8341 60" Rear Projection...
I used a toptak TP 110 code scanner to scan my 2001 toyota solara after several tries I continually get an error code each time. To check the operation of the code reader I tried it on a different vehicle...
you are facing the protocol problem, imports uses a diferent CAN interface, if your scan tool is not capable wont read it. try going to an auto part they're scan it for free
Oct 02, 2010 | Toyota Solara Cars & Trucks
WS-55411 What seven capacitors need replacing? 2-3 code Problem
U check the power supply board,check all cap,and replaced it?Ur tv make buzzing noise when u turn on power?Ur flyback is dead.
Mar 17, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Code error 06-43 et 06-40 copieur xerox 5837
Dear sir; Thank you to bring out the question to refresh my memory, I hope is correct! the error code 06-43 or 40 that all belong to optical problem, my suggestion ;
1, remove the glass plateform
2, check the exposure lamp continuaty, if nocontinuaty replace it.
3, check the exposure thermos fuse continuaty,if no continuaty replace it.
GOOD LUCK, if you need more help let me know
HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Xerox 5830 Copier
No picture or sound
Change both convergence IC's for reliability, then make sure both fuses are good.Next,fire up the set,check alignment.Let me know how it goes.
Sep 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
