Question about HP LaserJet 5L Printer
My printer hp laserjet 5l is printing in number and alphabatic what i do .
  • HP Master
  • 1,684 Answers
This is caused by one of two things. First be sure you have the correct printer driver installed, if you have printed to this printer before on this computer then you should be ok here. The other thing would be that the printer lost communications with the computer and when it reconnected the control codes had been lost. To check this, first power off the computer and the printer. Now check the connections between the two, the computer connection should be screwed tight and the printer connection needs to have both clips fastened. Now power up the computer and printer, try a test print, if it prints then you should be good. If you still get the odd print then replace your printer cable, be sure to get one that is rated IEEE1284. This rating insures proper bidirectional communications between the printer and the computer.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 29, 2010
Hello, I have a HP LaserJet 5L; I just put in a new cartridge and its printing letters and numbers and not the doc. i'm needing...please help.
This error is not caused by the cartridge, it is either a cable issue or a driver issue. Try reseating the parallel cable on the back of the printer and make sure the cable is securely attached to the parallel port on the computer as well. Also make sure that you are printing with the correct driver.
Jul 16, 2011 | HP LaserJet 5L Printer
Want LaserJet 5L driver?
You can download the drivers from this link.
Just select the operating system of your computer.
May 19, 2010 | HP LaserJet 5L Printer
Problems in printing from laptop to laserjet 5L printer
Try with other applications like Ms Word to check.
Jul 06, 2009 | HP LaserJet 5L Printer
HP LaserJet 5L wont do anything
First of all, I wouldn't spend 10 cents on this printer at this point, but is there a toner cartridge installed? It could be empty, and it's probably not going to print very well after all this time anyway. Try giving it a few shakes side to side to loosen any toner that may be inside, if that doesn't get it going, then pick up a new laser printer for $70-$100 (basically the price of a replacement toner cartridge)
Apr 13, 2009 | HP LaserJet 5L Printer
HP laserjet 5L prints only 2/3 to 3/4 of the page of a 1 page doc
which bit is usually missing?
If it only prints the 1st 3/4 ish of the page then it could either be the page slipping a bit due to poor pick up rollers or much more likely it could be that you are sending a large file to the printer and the printer does not have enough memory.
Try printing in draft or scale down the res/size of the file you are printing
Mar 18, 2009 | HP LaserJet 5L: HP 5L Monochrome Laserjet...
HP 5L printer Paper advance
Parts are no longer available. You might be able to clean the feed roller by removing the toner cartridge and cleaning the gray roller with isoprpyl alcohone.
Jan 04, 2009 | HP LaserJet 5L Printer
HP 5L printer feeds but does not print
May be a problem with the toner cartridge. Try changing first.
Dec 21, 2008 | HP LaserJet 5L Printer
In the middle of printing a document my laserjet 5L just screamed
Is the light flashing or on solid? They have different meanings
Nov 16, 2008 | HP LaserJet 5L Printer
HP 5l laserjet printing problem
AoA
dear sir
our printer not printing correctly. it print some other language in top of the page. please solve my problems
Aug 03, 2008 | HP LaserJet 5L Printer
HP Laserjet 5L feeds multiple pages through at a time
It prob. needs an overhaul/reconditioning/cleaning to soften up or replace the rollers and rubber pads in the paper path. I imagine it needs this about every 5-6 years. Don't know if new parts are still available for this great old machine, but it's worth trying to keep it alive, at least until you change computers and don't have a parallel output port anymore ;^).
Jul 26, 2008 | HP LaserJet 5L Printer
HP LaserJet 5L Printer Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
