Question about Gigabyte GA-K8VM800M Motherboard
PNY memory problems
Ram A: PNY 1 gig @ 200mhz
Ram B: Crosair 512 @ 200mhz
Ram A in both ram slots will not work. Computer starts up but restarts after it reaches windows load screen.
When I use both ram A and B in either ram slots, computer works but memory reads at 166
I have tried ram A on a separate computer and it works individually and reads at 200 mhz
My bios is up to date
is my problem because the gigabyte k8vm800m cant run ram A at its native speed?
According t this web site 200MHz not supported.
Supported RAM Speeds400 MHz · 266 MHz · 333 MHz
Thanks,
itsik hadar
Posted on Oct 20, 2008
  • 93 Answers
Sounds like its a ram frequency mismatch to be honest
altho they are both 200mhz there is a mismatch occurring
Posted on Mar 25, 2008
I have e-machines T5026 with an Intel Corporation D915GAG mother board which currently has 1.5GB Dual-Channel DDR @ 133MHz (3-3-3-8). I am trying to add 1 gig of PNY RAM, #MD1024SD1-400. When I installed...
You may be using the wrong parity or out Latency ram. if they are not similar in latency they will not work in tandem. Make sure both of the ram's are the same MHZ and CS latency. Also, you may have bad ram as well. Try using the new ram first to see if the computer posts, if it does, input the old ram in the second slot, and if that doesnt work, the ram is not compatible with each other.
Feb 05, 2011 | Intel D915GAG Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
I need to replace the 512 Ram Memory card with 2 new 1 gb cards
Yes that's correct simply turn off the power OFF from the computer and to make sure unplug it from the power outlet, then remove the existing 512 RAM and put the new RAM and then turn the power back ON and that's it.....
Apr 03, 2009 | Dell Dimension 2400 PC Desktop
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Sep 18, 2008 | Gateway 835GM (835GH) PC Desktop
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
Gigabyte GA-K8VM800M Motherboard Logo
299 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
