Question about Philips GoGear HDD6330 MP3 Player
It froze when i turned the mp3 player on it played one music and it froze........i can't listin to it or turn it off......what's the problem.please help
  • 8,596 Answers
Reset button will turn it off (actually, volume + plus play at the same time, I believe will reset it). - if the problem persists, then go to www.usasupport.philips.com and upgrade the firmware for your GoGear. Windows Media Player 11 will cause intermittent freezing on this device.
Posted on Mar 28, 2008
Reset how can I reset my gpx mw240 mp3 player
Does it freeze with all mp3 music?
MP3 files come in many different formats and it could be that the format of your mp3 files make the player "hang".
May 11, 2014 | GPX MW240 MP3 Player
Froze and won't come back on
Try connecting it to a computer if nothing Remove the back and check and see if the battery isn't fully connected push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screenand memory, Black screen Blue ring problem) and put the back on.Freezing up while playing songs Check and see if there is a boot file in any of the folders on the player use the Explorer to check Check both MTP and MSC modes and unhook your player
Jun 29, 2010 | SanDisk Sansa e250 MP3 Player
My Zen will not do anything,it's froze.
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
May 16, 2009 | Creative Labs Zen V MP3 Player
My zen mozaic totally froze, I can't even turn it off. The battery indicator show that it is half charged. I was just trying to rewind a bit, and the whole thing froze. What do I do now?
See if this works. If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Apr 16, 2009 | Creative Labs Zen Touch MP3 Player
My philips music device froze on me. i was trying to put music on and when i ejected it it froze in my music. i cant turn it off, change the song, or listen to music. please help!
There is a reset button.
If it freezes again after reset, go to Philips website, get the upgraded version of the Philips Device Manager and run the Update tab in Philips Device Manager.
-Tha Mp3 Doctor
Feb 18, 2009 | Philips SA3025/37 Flash MP3 Player
MA 715 Will not play all the songs written to it
u have to drag da music to the music files straight to da mp3 player u cant sync them because they will go strait to folders and u cant listin,,,,, if they are now in folders on ur mp3 go onto it from ur mp3 and take the nice long time of taking them out of the folders
Aug 15, 2008 | Nextar MA71520R Digital Media Player
Problems with my insignia mp3 player
A Possible solution is to charger it all the way up 'til it's full, and then try turning it on. If that doesn't work, you may have to call sansa, and/or take out the battery and put it back in. This requires a special screwdriver.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
Once i turn it on i cant turn it off and when i go to listen to music it just goes and restarts itself
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else?
P.S...Please rate accordingly...
Thank you
Computerrep
Feb 09, 2008 | SanDisk Sansa e260 MP3 Player
My mp3 player has froze
Maybe try taking the battery out and putting it back in, because once my mp3 player froze and that worked. It froze when I was going through menus when the song was playing still and it was probably too much...
Oct 28, 2007 | SanDisk Sansa m230 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
73 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
