Question about Whirlpool DU1055XTS Built-in Dishwasher
Clean light flashes it will not work whirlpool dishwasher mod #du1055xtvs
Same thing happened to mine - had to replace heat sensor
Posted on May 13, 2010
How do I reset blinking lights?
Switch the breaker off for a minute.....
Aug 26, 2012 | Dishwashers
Soap on dishes and door
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 02, 2011 | Whirlpool DU1055XTV 24 in Builtin...
What do you use to clean a dishwasher and how often do you clean it???
Hello, Thank You for using FixYa. I will be helping you today. Here is my cleaning tips Click Here
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Whirlpool DU1055XTV 24 in Builtin...
Hi, I have a brand new quiet partner 2, the model number du1055xtvq3, it stopped during the normal cycle and the normal and cancel lights flash at the same time. None of the buttons respond when pushed.
Unfortunately, the touch panel has experienced a failure. You can try disconnecting the power for a bout 5 minutes to see if it resets, but I doubt it will. The touch pad will likely need to be replaced. I will need the rest of the model number to give you the correct part information.
Kelly
May 25, 2011 | Whirlpool DU1055XTV 24 in Builtin...
No water is going to dishwasher.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
May 09, 2011 | Whirlpool DU1055XTV 24 in Builtin...
Our Whirlpool dishwasher (mod. #DU1055XTVS0) turns on but it's not getting the dishes clean. It also seems as though the top spray bar is not spinning. Is there a filter or something that's clogged?
heatman101
Apr 20, 2011 | Whirlpool DU1055XTVS Builtin Dishwasher
Model: Whirlpool DU1055XTVQ Problem: dishes come out dirty, especially in top rack. Water does not seem to be coming out of holes in either upper or lower arms with any force whatsoever. What do I do?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
heatman101
Dec 20, 2010 | Whirlpool DU1055XTV 24 in Builtin...
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
We have a dishwasher that flashes clean light on front panel and will not allow a new cleaning cycle. Mod GU3200XTPS3 TYPE 577-0
Make sure the control panel is not locked. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored. If the lock symbol is lit, press and hold HEATED DRY for 4 seconds. The light turns off.
If the control panel is not locked and the problem still occurs press the Cancel/Drain button to drain all water and clear all indicators. (It might take 2 minutes to complete this action.)
Jul 08, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Whirlpool DU1055XTS Built-in Dishwasher Logo
149 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
