Question about Black & Decker Le750 Lawn Edger
Problem with my B&D LE500 lawn edger. Will run good then quits. pressing trigger several times edger starts. may keep running or quit. are there points or something electrial that could be problem?
  • johnpthomas Jun 22, 2010
    Thanks for the input. I did take the edger to B&D shop. They did find the switch defective. But they said the part is no longer available. Could this be? Now what? Come on B&D how 'bought some help!!
  • 38 Answers
Check the switch, it could burnout. The trigger switch made on this model are very cheap and can not supply current to motor for a long time without burning out. So it could be that switch has melted, and plastic is covering parts of the terminal.
Posted on Jun 16, 2010
My LE500 edger just stopped. After reading a number of posts, checking the switch, verifying the brushes are in working order, etc.; I found another solution. Once you have taken off the black cover to expose the motor, look at the inside of the cover itself. There are, or should be, two rubber stoppers or cylinders. These stoppers press down on the brushes, which in turn positions the brushes against the armature. If there is unsufficent pressure on the brushes they will not align properly and the edger will not run. I extended the stoppers slightly from the housing, reassembled the edger, and the edger works fine.
Posted on Mar 19, 2012
Runs at different speeds and quits
Try changen battery. Might be a short.Was it left in the rain (noy good)
Aug 12, 2012 | Worx GT WG150 10 in. 18 Volt Cordless...
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
I have a poulan 335 weedeater it is six months old it starts with choke but when you press the trigger it bogs down and stalls you can keep it running if you keep the trigger pressed but if you let off it...
If its only six months old i would think it is a carb adjustment issue ( running too lean ) you need to richen up the mixture by un screwing the mixture screws, start with 1/8 turn on each
Jun 30, 2012 | Poulan Garden
My Ryobi trimmer quits running after I turn choke off and pull trigger to speed it up
run it with chock on half way it will start running better after a wile
Sep 20, 2009 | Garden
New trimmer same problem
the carb screws need to be reset
Sep 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Black & Decker Le750 Lawn Edger Logo
869 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
