We have an Akai flat screen tv and a phillips dvd player it is all connected but we have no sound what could our problem be I tried checking all the cords and adjusting the tv settings.
  • 53 Answers
This is going out on a limb, but are you using an s-video or component connection and forgetting to also use sound cables?
Older style A/V cables have a yellow connector for video and red and white connectors for sound. Superior s-video and component connections (which if you aren't using, you really really should) are for video only, and require also using red and white audio cables. S-video is a big connector that looks like the kind used on a computer mouse or keyboard, and component uses three cables, red, green, and blue connectors.
Posted on Mar 25, 2008
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
Flat screen TV only has volume. When we turn it on, the screen is light gray with a darker gray stripe in the middle. TV is only three years old! The dvd which is part of the TV stopped working in the...
Sunds like a tv issue. I would try to connect a dvd player or vcr to it to see if that works to eliminate the service provider first, if it still doesnt work its the tv.
Nov 20, 2010 | Akai Televison & Video
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Connecting ps3 to akai lct2060
I had mine connected with HDTV cables with no problem. It also took care of the poor sound quality issue with the internal dvd player.
Dec 25, 2008 | Akai LCT2721AD 27 in. LCD Television
Connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Dec 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
TV turns itself off after turning on. TV screen goes black.
Based on what I have read AKAI has reoccurring problems with power supply and bad DVD sound. The problem you have is caused by the DVD player trying to start. Never leave a disk in when you shut it off or you will have the same symptom you are describing.
Oct 07, 2008 | Akai LCT2721AD 27 in. LCD Television
Sony Bravia with Phillps dvd player
The DVD player may have multiple output formats that can be displayed. Sounds like you have the composite output selected when you have the component output selected on the DVD player. Check the menu options on the DVD player and confirm they match the way you have the player connected
Aug 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
