Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Hello, I have a Sony KDL-52W4100 with retrace lines on the bottom 1/4 of the panel. Looks like a vertical problem from the direct view sets. Any idea if it is the t-con or main board? Thanks.
  • Bob Apr 29, 2010
    Thanks
  • 10,594 Answers
If lines at 1/4 of bottom part of screen are across the screen then it could be T-Con or LCD Panel problem and if lines stop in halfway then its confirmed LCD panel problem.
Below exploded view (taken from service manual) shows T-Con board location in this tv.
Hope this info will help you.
Let me know if you have additional question.
Thanks.
Posted on Apr 29, 2010
Fix vertical lines
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
https://youtu.be/wUpnETSm6_k
Jan 03, 2016 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Vertical lines on screen
There are many reasons for this fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Vertical line fault to LCD TVs are given with illustrations. You can compare it to that of your TVs, and can get an idea about the fault.
Jul 16, 2014 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 29, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Black vertical line on screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Oct 05, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Vertical line
Most probably the vertical deflection amplifier is failing. The most common part that fails is the vertical output transistor.
The set is too old to find documentation on part numbers and descriptions. Probably the part is no longer available and you will need the assistance of someone who can help you find an equivalent transistor that will do the job.
Of course, without testing we cannot be certain the failure is the output transistor. It could be from something else such as the voltage regulator that feeds the dc line to the vertical section. Could be the vertical synchronous level that goes too low to trigger the vertical sweep generator.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals
Good luck.
Jun 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
We need our Sony 52W4100 Bravia screen replaced. What is the cost?
Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV
Part # 1-802-791-12, cost approx $2,251.54 + core
Parts reference: Andrews electronics, 800 289 0300.
May 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Solid line appearing from top to bottom middle to the left
Ur horizontal,Vertical ic coverter it dead need replace the board.
Aug 13, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
206 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
