Question about Kenmore 15864/15862 Top Load Washer
I have a Kenmore Washing Machine top loader that I replaced the motor for and after I put the washer back together my drum is off kilter and when filling up with water it leaks out and on the floor. What should I look for to fix this problem?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
With the cabinet off, I'd also check the hoses to and from the pump as well as the inside of the pump itself.
I'd also check the gaskets on the bottom of the tub.
Posted on Apr 29, 2010
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Continous loud noise in fast spin cycle, six year old, Kenmore front loader (washing machine). The shocks have been replaced. Have checked the bearings, belt and motor which seem OK. The weights seem to be...
if it sounds like an aircraft taking off, it can be nothing other then the bearing, sorry. this is how they sound before they break completely, most commonly caused by not using high efficientcy detergent. need back half of tub replaced. very labor intensive and must have prior experience becuase whole machine needs to be disassembled
Nov 24, 2009 | GE WBSR3140DW Top Load Washer
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
The drum is not spinning. I hear a noise like when you stick something in your bike spokes.
Assuming that this is a Kenmore / Whirlpool top loader with a direct drive system, the first thing to check is the motor coupling.
The transmission and motor have plastic parts that connect through a rubber coupling.
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:661560Substitution:285753A $18.50 If the coupler rubber piece wears out, the pins on the motor and transmission sides will rub together making the sound.
If the coupler looks good the problem is likely in the transmission.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Kenmore HE3 Front Loader Washing Machine tumbler
The metal basket (inner basket) has a broken spider (these are the support brackets that hold the basket to the bearing shaft). The inner basket will need to be replaced and the front and rear shell of the drum may also need to be replaced depending if any other damage has been done. It's a big job, about 2 hours for a good tech.
Feb 19, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 110.24422300 Top Loader Washing Machine
We have one of two situations happening here. Either your timer is going or the motor is blown. The other thing is to put the machine into spin and see if it drains, let me know!
Oct 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore oasis washer
top loaders use the same motor for wash pump and spin to spin the clothes the motor direction is reversed and a solenoid releases the drum brake allowing the drum to rotate this is governed by a set of clutch shoes in the pulley if these are worn then the machine wont spin at full speed but ol on the display indicates overload so check the solenoid is releasing the drum usually heard as a loud clunk on spin start
Apr 01, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore 15864/15862 Top Load Washer Logo
95 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
