Question about Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax 2800
I have a message stating "Please Open Door" so I have plus taken out cartridge - replaced cartridge back into machine - closed door -- then it says Printing - you hear the noise of it Printing but nothing comes out.
The paper is not jammed. It said earlier today that it was Out of Memory - so I don't want to unplug as I will loose anything in memory. Please help. Thanks
DJYar
  • 41 Answers
SOURCE: Brother IntelliFAX 2800 - Paper Jam
It could be one of two things. First and most common is one of the sensors is dirty/stuck and a quick round of compressed air will usually take care of it. This is especially common if you have been running 3 hole punched paper as the loose punches tend to cover sensors. Recycled paper also tends to leave some dusty residue and that will, in time, obscure the sensors, along with a dusty environment or if the machine is on the floor. Another possibility is one of the physical sensors got knocked off course a bit. This could be caused by pulling out jammed paper too roughly or running lots of heavy paper through the unit. I would do a visual inspection for any bent or crooked parts.
Posted on Aug 29, 2007
Avwrexit
  • 47 Answers
SOURCE: Need user guide/manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2800_2900_3800_MFC_4800_EN_64.PDF
Posted on May 31, 2008
SOURCE: reset the drum count on a brother intellifax 2800.
Drum counter is reset by installing a new drum which contains a specifically designed "starter sheet" that is passed through the machine when it is installed, and triggers the paper sensors in a specific pattern, resetting the electronic counter.
If you have installed a new drum and the message remains......I suspect that it was a remanufactured unit that did not include the "starter sheet" Is that the case?
Posted on May 03, 2009
  • 46 Answers
SOURCE: REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Posted on Sep 03, 2009
FixinFax
  • 3085 Answers
SOURCE: Turn off error correction mode on Brother Intellifax
It won't help. fax machines are ANALOG, magic jack is DIGITAL
Posted on Dec 17, 2009
Testimonial: "Thanks!"
There are thick black lines down the incoming fax pages of our Brother Intellifax 2800. How do I fix it?
You need to open the front cover of the machine and remove the cartridge( drum and toner) On the tope right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 08, 2010 | Brother IntelliFAX 2800 Laser Fax
Brother intellifax 2800. Replaced drum, display
Open the drum cover and hold down CLEAR for 10 seconds.
Jan 28, 2010 | Office Equipment & Supplies
After paper jam, prints total smudge on Intellifax 2800...please
This is the test to determine toner/drum or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner/drum cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Mar 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Need to replace toner cartridge, in brother 2850 laser fax
take the drum unit out which contains the toner cartridge, buy new brother toner cartridge and reinsert it in to the drum unit and then put it back into the machine and you will be good to go
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Jan 07, 2008 | Brother IntelliFax-2820 Laser Fax
Problems sending and receiving faxes
then there is a sensor problem, here is the manual check troubleshooting section
http://www.retrevo.com/s/brother+2820+fax++manual
Sep 07, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
19 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
