Question about Simplicity Performer S110 Mechanical Sewing Machine
My string keeps braking at the tension discs how can I elimante this to keep sewing
    President:
  • 1,619 Answers
Lower the tension on the discs and double check the routing of the thread.
Posted on Apr 29, 2010
Hi, my elna lock f4 keeps on breaking the nr2 string. I have treid everything, changing tension...... please help
try changing the needles, also try adjusting the tension, make sure it's threaded correctly
Nov 23, 2014 | Elna Sewing Machines
My top thread keeps snapping
Sounds like your tension is set too tight for the thread. Or you are using a poor quality thread that unravels and keeps knotting as it comes through the needle. Or you have a block between your tension discs. Pull a thicker thread through the discs to clear anything that is there.
Oct 06, 2014 | Sewing Machines
Needle keeps braking on the juki sewing machines ddl 555on
Hi - not an expert but from my own experience would look at two main possibilities, a) thread tension is too tight or b) the needle holder has got out of alignment
Aug 24, 2012 | Sewing Machines
Haven't had the Singer Sew Simple very long. Second time to use it. Ready to throw it out the window. Bobbin tension seems to be off. Thread keeps knotting up and breaking under fabric, jamming the...
Have you tried re-threading it? Remember to keep the presser foot up as you thread so that the tension discs are open. Re-thread the upper thread because it can often cause bobbin jams.
Perhaps your tension discs are blocked, try running a thicker thread through by hand to clean them.
Check there are no broken threads in the bobbin raceway.
Sometimes the wrong size needle upsets the tension.
Sep 15, 2011 | Singer 3116 Simple
My machine will not stitch - keeps breaking the thread in the needle - all i did was to refill the bobbin with cotton and now i can't get it to do anything, unfortunately i don't have a manual to...
Lower the tension as much as you can without ending up with a knotted string. You should be able to pull the thread by hand through the needle and have just enough tension so the bobbin does not keep spinning when you give a short, sharp tug to the thread.
Hope I helped!
Jun 08, 2011 | Brother LS-2125 Mechanical Sewing Machine
Thread keeps breaking, can't seem to get the
1. Maybe you are using the wrong size machine needle or poor quality thread.
2. You must always lift the presser foot before threading the machine to release the tension discs.
3. Maybe you have broken thread stuck in the discs or bobbin race. Give them a clean. Pull a thicker thread by hand through the tension discs when the presser foot is up.
Jun 01, 2011 | White Sewing Sewing Machines
Bottom tension very loose, looks like a crocheted string. I've changed needles, bobbins and tried adjusting tension.
Rethread your machine, you haven't got your thread going through the tension discs right or your thread is tangled
Aug 30, 2010 | Singer 2950 Mechanical Sewing Machine
Thred keeps braking
It might be tension to tight, threaded wrong or the bobin isn't thread the right way.
Apr 17, 2009 | Kenmore 15208 Mechanical Sewing Machine
Bobbin holder keeps catchin thread
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Jan 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Simplicity Performer S110 Mechanical Sewing Machine Logo
103 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
