Question about Kenmore 24032\24036 Top Load Washer
Washer does not fill with water
The washer will no longer fill with water whether starting a load or in any of the rinse positions. Water is available and pressure is normal. Suspect problem may be the inlet valve. Washer is 3 1/2 years old.
    President:
  • Kenmore Master
  • 2,651 Answers
, did you try changing water temps switch to different settings, hot cold amd warm alll no good?? do you even hear a slight humm when trying to fill???, how about trying to put into spin cycle, does it do anything??? if you listen closly (put your ear to the timer knob assy)can oyu hear anything??? if not its quite oossible that you have a power issue, check your incoming power for 110 volts.
Posted on Mar 25, 2008
My drum fills with water and is not turned on
Sounds like water control solenoid is stuck in the open position.
The hot and cold solenoids are located just inside where the hoses attach to the washer.
Feb 28, 2015 | Frigidaire Affinity FAFW3801LW 27"...
Star washing went get to rinse circle stop, press stop bottom and start bottom tries to start but not work
if you're saying it dies in the rinse cycle you could have a problem with your cold water not coming into the washer,the washer only uses cold water in rinse cycle,no cold water the washer won't run,try starting it just with cold water and see if it fills,if not bad water valve or problem with water in house valve or bad hose.
Apr 08, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Hiw many gallons of water with 2 rinses does a top
Your washer takes 35 gallons to wash and 35 gallons to rinse. Ask me how I know? Well I work on them but last December my washer (which is the same as yours) developed a problem with the cold water inlet valve. My inlaws and daughter and friends all come by at different times to use paws paws washer. They pass 50 laundry mats to come to my house. Just for fun I told my wife to get a 5 gallon bucket and fill the washer up. It takes 7 buckets to fill the washer up and get it to start washing. Later she decided to run a water hose out to the washer and fill it up. Then my mother in law suggested she put the washer on rinse and fill the tub. That told me I had a timer problem. But luckily I have 2 or 3 washers around the house I can get parts off of. So to recap: 70 gallons of water to wash a full load of clothes is what I guesstamate it took. Did that slow down my inlaws? Nope.
Mar 05, 2010 | GE WHRE5260E Top Load Washer
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Robert Rankin
