Question about Samsung CLP-610ND + Demo Laser Printer
Adc slope error cycle power what does this mean?
4 Suggested Answers
  • 13 Answers
SOURCE: Samsung clp-610 has an error code of
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Posted on Nov 24, 2009
  • 13 Answers
SOURCE: Samsung clp610nd ADC Power Slope
Ezrahite
  • 2632 Answers
SOURCE: There is an "ADC
Welcome to Fixya. ADC Slope Error Cycle Power means that The temperature slope for ADC (Analog to DigitalConverter) detects the value out of the normal range. This is a Service Call Error of CLP-610ND
Solution: This problem can be fixed by just Power Cycle. However, if the problem persists, contact the service representatives.
You can also refer to the user manual below.
Samsung CLP-610ND User Manual
Thanks for using Fixya.
Posted on May 19, 2011
HOW DO YOU PUT REFRIG IN DEFROST MODE WHEN IT HAS ELECTRONIC DEFROST CONTROLLER
You didnt give the make of the ref.; But your solution is here for most all
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, see picture...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. A close up common way *this* version of the Maytag/JennAir control is wired.
Amana also has a version of adaptive defrost, see info sheet for some help on the Amana version. Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A ?¿½d?¿½ in the freezer temperature window and ?¿½F?¿½ in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. ?¿½d?¿½ and ?¿½F?¿½ will be displayed until the defrost cycle is complete. (approx. 8 minutes)
For some Whirlpool refrigerators - some Kenmore refrigerators are made by Whirlpool ( 106.######## )
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
?¿½ If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
?¿½ If the relay clicks two times, check for an open bimetal.
Maytag S-S Refrigerator MSD2756GEW forcing defrost cycle
I replaced my defrost heater two weeks ago, but the frost built back up on the evaporator coils. Replaced the adaptive defrost board with new ( Maytag p/n 6100598 8 ) board. Want to force a defrost cycle to see the heater work, so I shorted the L1 pin to adjacent pin (now called DOOR instead of TEST) for three seconds and nothing happens. Compressor keeps running, fans still going etc. Tried pressing the door switches 5 times in 6 seconds and that doesn't work either. Any hints on how to get the defrost cycle to initiate?
This might help, a copy:
The issue is that some 12002104 ADC boards have been shipped in the 61005988 ADC board box. Do not reorder the board, the 12002104 board will function the same in place of the 61005988, but you must use the forced defrost method for the 12002104. Jumping "L-1" and "door" will not initiate the forced defrost function.
To Initiate Forced Defrost Cycle:
Cycle cold control on and off three times in six seconds. The cold control needs to be left in the closed (call for cooling) position for the defrost system to energize on all platforms. It is not enough to cycle the cold control knob, the contacts must actually open and close (open doors for a period of time if necessary to force the control to call for cooling). In most cases, you can hear the contacts open and close if they are doing so.
To Terminate Forced Defrost Cycle:
Disconnect power for five seconds.
You were right. I cycled the cooling controls three times and it went into a defrost cycle. Thanks.
Aug 08, 2011 | Refrigerators
Fridg. not cooling. digital display not working, frezzer thawing.
First Test Method:
Second Test Method:
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Jun 11, 2011 | Whirlpool Refrigerators
We have a Kenmore Elite Freezer Model #253.29082994. We had the freezer plugged in and it was working fine. We unplugged it and moved it and now when we plug it in it won't start. Is there some kind of...
You refrigerator was made by Frigidaire Adaptive Defrost Controls Frigidaire Refrigerator Trouble Shooting and Diagnosing
On the initial plugin, or when power is restored to the fridge after a power outage:
If terminating thermostat is open, the fridge enters a compressor (cooling) cycle.
If the terminating thermostat is closed, the first defrost cycle occurs 1 hour
after initial plug-in.
Maximum defrost cycle time is 24 minutes.
Minimum time between defrost cycles is 6 hours. (compressor runtime)
Maximum normal clock time between defrost cycles is 12 hours.
Maximum time between defrost cycles (in "vacation" mode) is 72 hours.
Vacation mode is not entered unless the door has not been opened in at least 24 hours.
Note that the ADC will only enter the defrost mode if the terminating thermostat is closed. If the terminating thermostat is open when defrost is initiated, the ADC board will wait for six minutes and then return to the cooling mode.
ASSUMING that the fridge has been on and running,
and the terminating thermostat is closed,
defrost is initiated by pressing the door (light) switch
at least five times within six seconds.
The defrost heater should start heating up within 8 seconds.
If the above procedure caused the heater to heat up, the ADC board is probably bad; replace it.
If the defrost heater does not heat up, test the defrost heater, terminating thermostat and cold control for continuity as follows:
Unplug the fridge from the wall. Unplug the ADC board from its connector.
Test the connector for continuity between the following leads:
Defrost Heater = DEF TERM (blue) to DEF OUT (brown).
Terminating Thermostat = DEF TERM (blue) to NEUTRAL (lt blue).
Cold Control = COLD CONTROL (orange) to L1 (black).
Replace the defective component.
dvfxnxxsllnll3xsyszyldhiovfnqznnvujbtluyw2q4uxl2ntjkcdj6njhpmxnefkntwws4bi9kdg83ay5nd0jdsnhpljetrth0supsduvxugpczlkyaszhzu1onu9xwdfjv0xta0jidtfiwg%3d%3d
Apr 26, 2011 | Kenmore Freezers
How do i get unit to go in deforst
First Test Method:
Second Test Method:
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Nov 12, 2009 | Samsung CLP-610ND + Demo Laser Printer
Samsung clp-610 has an error code of ''adc slope error cycle power'' what does this mean? How can we rectify the problem?
Sep 11, 2009 | Samsung CLP-610ND + Demo Laser Printer
Whirpool frost free-fridge temp is not working
First Test Method:
Second Test Method:
� If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
� If the relay clicks two times, check for an open bimetal.
Jan 06, 2009 | Whirlpool Refrigerators
Samsung CLP-610ND + Demo Laser Printer Logo
272 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
