Question about Dell 924 All-in-One InkJet Printer
How do you re spool so I can print - Dell 924 All-in-One InkJet Printer
  • 4,041 Answers
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
    Guru:
  • 109 Answers
If you using Windows based OS then open the SERVICES window (press Window's LOGO + R) and type " services.msc ". When the Services window appears look for " Print Spooler ", right click and select restart. Thats how re-spooling is done...
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Dec 03, 2016 | HP Office Equipment & Supplies
I am trying to print a pdf proof of payment and my printer is giving me error 9783
  1. Stop the Print Service.
  2. Open Terminal (/Applications/Utilities).
  3. Execute these commands: $ sudo rm -r /var/spool/cups/tmp $ sudo mkdir /var/spool/cups/tmp $ sudo chmod 1770 /var/spool/cups/tmp
  4. Start the Print Service
Mar 04, 2011 | Office Equipment & Supplies
Hi my printer will not print. it is saying printer spool error.
> spool error
S.P.O.O.L. == Simultaneous Peripheral Output On Line
The "spool" is a combination of disk-space on your 'C:' drive, and software to "accept" the print-image (as fast as MS Word can create the print-image), and save the print-image to disk-space,
so that MS Word can report "print completed", so that you can use MS Word, instead of waiting until the physical printing has completed.
Then, the printer-spooling software will read from the print-image file, and send it to the printer, only as fast as the printer will accept it.
Feb 05, 2011 | Xerox Office Equipment & Supplies
Even since we install the edimax server, the printer will just halt and we have to reset the spooler again
Setting the location of the spool folder By default the spool folder is located at systemroot\System32\Spool\Printers. However, this drive also holds the Windows system files. Because these files are frequently accessed by the operating system, performance of both Windows and the printing functions might be slowed.
If your print server serves only one or two printers with low traffic volumes, the default location of the spool folder is sufficient. However, for high-volume printing requirements, to support large numbers of printers, or to support large print jobs, you should relocate the spool folder. For best results, move the spool folder to a drive that has its own controller, which reduces printing's impact on the rest of the operating system.
For information on relocating the print server spool folder, see Change the spool folder location.
To set up a printer to print to multiple devices
  1. Open Printers and Faxes.
  2. Right-click the printer you are using, and then click Properties.
  3. On the Ports tab, select the Enable printer pooling check box.
  4. Click each port where the printers you want to pool are connected.
Notes
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • With printer pooling, the printers must be the same type of printer using the same printer driver.
  • The previous procedure assumes the printers you want to pool are already in the Printers and Faxes folder.
  • Check for print jobs in que,this can cause the printer to spool if a print job is in que.
Dec 09, 2010 | Edimax PS-3103P (ps-3103p) Print Server
The black ink is not printing clearly, but I just put in a new ink cartridge
Hi !!
As you are using a new cartridge, check the tips below that might help.
In this tip you will learn that how to improve the printing quality. Today most of the printers provide you the method to improve the quality of the printing. In the following section you will find step by step instructions on how to improve the printing quality.
* Go to Start > Control Panel
* In the control panel click on the “Printers and Other Hardware” or “Printers and Faxes”.
* Double Click the Printer’s Icon.
* Click the printer preferences in the printer menu.
* Select high quality or best print option in the printer preferences.
In the Windows based operating systems you can improve the quality of your printings through the above mentioned steps.
Dealing with Spool File
In Windows XP Professional, Windows 2000 Professional and Windows 2003 Server allows you to adjust the spool file settings for any type of printer to improve the quality. Spool file is a temporary file that holds the document while they are printed.
A spool file is created when you send a printing request from an application such as WinWord. After spool file has been created, Application gets control and it sends the document from the spool file to the printer. Moving the spool file to a faster hard drive or empty disk drive can improve the speed of the printing.
* Create a folder on any drive and name it whatever you like.
* Go to the Control Panel > Printer and Faxes.
* In the file menu select “Server Properties Command”
* In the “Print Server Dialog box” select advance tab.
* In the spool folder text box type the path to the new folder, which you have created in the first step.
* On the confirmation box, click yes and close printer and faxes.
* Select your active printer’s icon > right click > properties > Advance tab > find the spool settings.
In the spool settings dialog box there are two sub settings that allow you to control how fast should be the printing operation. By adjusting the settings in the spool file, you can control and quality and speed of your printer.
Some General Tips
* Always use quality paper.
* Clean your printer from dust and debris.
* Make sure that there is a sufficient level of ink present in cartridges.
* Set the printing quality to high through the printing preferences.
* Read manufacture’s manual for getting the optimized performance.
* Give adequate ventilation to the laser printers because they dissipate heat.
* Clean the corona wire and roller when you change the cartridges.
Regard's
Anurag Shukla
Sep 03, 2009 | Office Equipment & Supplies
HP2420dn printer spools SLOOOOOWLY
try to change spool settings
Control Panel-Printer Properties-Advanced Tab
Select Spool Print Documents-Start printing after last page is spooled.
Aug 11, 2009 | HP LaserJet 2420 Printer
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
Printer
spooling, is where the information being sent to the printer is being checked/converted for the printer driver , prior to being printed
Jan 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printing
Disable printer spooling in the printer properties and enable direct print
May 14, 2008 | Sharp AR-BC320 All-In-One Led Printer
Spool locks
I had the same problem - to fix it, I disabled "Enable Bi-Directional Support" under the printer's properties (in windows, right click on the printer in "Printers and Faxes", go down to properties).
Worked like a charm.
Nov 08, 2005 | 3Com OfficeConnect Wireless...
Dell 924 All-in-One InkJet Printer Logo
1,182 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
