Still flickering monitor Proview MA-782KC
Hi just joined fixya, before post this Q, read all related topics, i resoldered all those capacitors in power suply board, still flickering, is there anything else i missed here? apart from flickering, sound and backlights working fine. Now i use other monitor, so that is DEFINETELY monitor problem, video card is ok. Is there anybody who experienced the same problem and guide me what other component need to be replaced?
  • CrazeeRay
    CrazeeRay Apr 29, 2010
    Sorry, they have been replaced with new ones, not resoldered old ones, my bad ;)
  • 1,684 Answers
Hello, Did you just resolder the capacitors? They need to be replaced not resoldered. When they start failing they can give exactly the type of problems you have, flickering or wavy picture, Slow display of picture when you power up monitor or very dark picture. Here is a link to an article that talks about replacing the capacitors and what you need to look for and what to replace; http://www.ccl-la.com/blog/index.php/capacitors/ If you have any questions please let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 29, 2010
Testimonial: "Thanx 4 your response Buddy, i was actually hoping to get your advise, because when i was reading other posts, your solutions were best, u r Real Pro!"
My Proview PL926Wbi displays for a few seconds flickering then shuts itself off there is a crackling noise in the rear please help.
Look at the caps, solder joints, lamps connectors for arching sign.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 16, 2010 | Proview PL926WBi 19" LCD Monitor
Proview fv-926afw 19'' LCD flickers and buzzes
If you have a capacitor tester.. i'll be much better at least you would know which caps that actually failing..
I would replace all the caps if you dont have the tester.. and while your at it. try to resolder connections and some parts like transistor etc.. maybe they have "cold solder"
May 04, 2009 | Panasonic Computers & Internet
I have a Proview MA-782KC 17" TFT Monitor and when I switch it on the green power light flashes but nothing is appearing on the screen. When it was working properly the green light remained aon all...
I`ve opened it up and there are several 470uF capacitors in the power circuitry which are obviously bulging, meaning they are in considerable distress. I am ordering some replacements and will fit them when they arrive and see if they get it working. I`ll let you know :)
By the way, I don`t recommend this for anyone not versed in this kind of repair. Messing about inside the power circuit of a monitor can KILL - even unplugged, unless you know what you are doing, so please take care.
Sep 09, 2008 | Computers & Internet
LCD Monitor goes off after 2 sec.
Check all cracked solder joints and resoldered and check two smd transistors near the inversors good luck
Aug 11, 2008 | Proview PL913B 19" Flat Panel LCD Monitor
I have a Proview 700P MA-782KC LCD Monitor that has a slight 'hums' when plugged in, but doesnt seem like it's getting power. The LED doesnt do anything (stays off) and the On button no longer responds....
can u tell me the model no on the power supply plz as i moved home and lost my power supply soz i cant help u with your problem but maybe you could help me with mine thanks
Mar 28, 2008 | Televison & Video
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
Filter
baillie,
The filter is a matter of personal preference. Your monitor itself doesnt need it.
If you get a lot of eyestrain while working on your computer, then it will help you.
Jan 22, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Proview 700p problem
DISPLAY IS GOING OUT SIMPLY GET NEW MONITOR
Jan 16, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Oct 17, 2007 | Proview PL926WBi 19" LCD Monitor
PROVIEW MA 782KC PRV MA 782KC 17 TFT
You need to set the resolution correctly on the computer.
Oct 06, 2007 | HP Pavilion 8860 (P2941A) PC Desktop
Computers & Internet Logo
381 people viewed this question
David Payne
David Payne
