Question about KitchenAid KGRA806PSS Gas Kitchen Range
Oven takes forever to reach temperture - KitchenAid KGRA806PSS Gas Kitchen Range
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Apr 29, 2010
  • KitchenAid Master
  • 8,220 Answers
Your ignitor is weak:
Why oven does not reach temperture
what's the model number?
May 20, 2014 | Kenmore Ovens
Problem with Maytag oven
Sounds like it may be the igniter failing
Feb 13, 2014 | Maytag Ovens
Takes forever for stove to preheat and takes forever to cook
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Why does my bike take so long to reach a normal operating temperture? It will keep cutting out until at least 4 miles is reached.
only 4 miles????? thats not bad realy,,after all its darn cold air out there!!,you never start it and let it run up for a fuw minuets before you drive away then? a cold engine will have maximum engine were done to it if driven cold! have you checked the thermostat out? if its stuck open the engine will take longer to warm up,,,but 4 miles???? thats nothing my BMW takes forever to warm up,,,the fan has only ever started up once in 3 years of riding it??? i was sat in a jam up for 30 minuets first with the engine ticking over!!! dont worry it will warm up quicker when the wether warms up
Jan 28, 2010 | 1995 Suzuki GS 500 E
Problem with oven is it takes hours to reach temp
temp. sensor isnt working you would have to call in a repairman
Nov 25, 2009 | Magic Chef 31000 Gas Kitchen Range
The oven for my G.E. gas stove takes forever to reach 350 deg.
Here are the common causes.
1. First check that the bake and broil burners/ignitors are working. If not, you may have a bad ignitor.
2. If #1 is ok, then the burners must be short cycling, that is, they are ON for too short a time then OFF again.
#2 can be caused by either a bad temperature sensor or a failure in the control board.
The temperature sensor needs to be checked by disconnecting and measuring it's resistance.
If the sensor is good, then the problem is in the control board. We repair this particular problem with the controller quite often. If you want, I can have a look at it for you, if you can have it removed and sent to us.
Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | GE Cooktops
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
KitchenAid KGRA806PSS Gas Kitchen Range Logo
486 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
