Question about Car Audio & Video
Timing Belt Jumped TIMe
I have a 94 dodge stealth that jumped time need some help. PLEASE?
    Problem Solver:
  • 8 Answers
I know that when mine did that it had something to do with the waterpump going out. Since it's well hidden I had a mechanic work on it.
Posted on May 20, 2009
Why 2000 dodge caravan suddenly lost compression on 2.4 engine
Possibly timing belt worn out an jumped time ! How many miles on it ? timing belt should have been replaced around 60,000 miles !
Apr 27, 2015 | 2000 Dodge Caravan
1999 dodge status jumped timing how do i adjust it without timing light
if it jumped timing that usually means the belt or chain has skipped. this is not an external adjustment. It requires replacement of said chain or belt. Hopefully no valves were damaged.
Feb 22, 2011 | Dodge Stratus Cars & Trucks
Replace timing belt on 94 dodge stealth 3.0 dohc need to know everything to replace timing marks and route of belt
timing marks are easy to see,(on the top of gears and line up with the metal indents above them) change the water pump it idles on it... you need a cam holder to hold your cam gears in place when changing they will spin when you take off the old belt... it is an easy timing belt for a *** V6...!
Apr 06, 2010 | 1994 Dodge Stealth
1992 dodge spirit wont start timing belt not turning
it has jumped time you wil have to replace timing belt.
Mar 26, 2010 | 1992 Dodge Spirit
Jumped time
If it jumped ignition timing then the timing belt needs to be replaced. Does the distributor still turn when you turn over the engine? If not then the timing belt is broke. Hope this helps. Remember surveys, thats what keep us here for you
Dec 23, 2009 | 1991 Geo Tracker
What are the symptoms of a broken timing belt on a dodge cummins diesel engine?
if the timing belt is broke - the motor will not crank - if it jumped time - it may run , but be low on power
Sep 25, 2009 | 1999 Dodge Ram 2500 4WD
Timing
IF THE TIMING HAS JUMPED THEN IT IS TIME TO HAVE IT REPLACED. THE BELT MAY BE WORN TOO BAD OR MAYBE THE BELT TENSIONER HAS FAILED. THIS JOB IS NOT TOO SIMPLE AND SHOULD BE DONE BY A PRO. I HOPE THIS HELPS. PLEASE FEEL FREE TO ASK ANY MORE QUESTIONS. THANKS FOR USING FIX-YA AND FOR AN HONEST RATING. GOOD LUCK
Aug 27, 2009 | 1995 Chevrolet Cavalier
My 03 dodge neon has jumped time. What do I need
Most mechanics would pull the spark plugs and check the compression in the cylinders, but usually anyone with a trained ear can tell by the sound of the starter when cranking against the compression of each cylinder. Many of the smaller engines today have valving designed so that when they are out of time, the pistons interfere with them. That means two objects try to take up the same space at the same time and at minimum the valves bend. Worse case scenario would be upper head/camshaft damage and possible piston damage. That's pretty severe. You won't know until you get the valve cover off or maybe deeper. Hope that helps.
Jun 26, 2009 | 2003 Dodge Neon
Im 98 dodge avenger died going down the road and now wont start.
Your timing belt jumped. Need to have belt replace and timing reset with timing jumped hope no engine damage
Nov 02, 2017 | 1997 Dodge Avenger
Timing settings
my jeep has jumped time and i need to know the exact degrees to set it at please and thank you.
WRONG!!! WRONG!!! WRONG!!!
The first thing you need to do is to find out why it jumped time. Jumping time is not normal and shouldn't happen.
Tell me the last repair that was done on the jeep.
When was the timing belt last changed?
Were OEM parts used?
Were tensioners and pulleys changed?
Dec 27, 2008 | 1995 Jeep Grand Cherokee
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
