Question about Linksys Wireless-G Broadband Router
Connection to the internet from one computer to the other
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 107 Answers
If you can get ONE computer connected to the internet and want to connect the other computer THROUGH that first computer (though I don't know why you'd want to unless that first one is setup as a firewall), tell the Windows network wizard that you're connecting through another machine instead of directly. A better way to do it is to buy a router/switch, connect ONLY that one to the internet, then connect the other PC's to that router/switch.
Posted on Apr 29, 2010
One computer will not connect to the internet
If your computer can't connect internet, but another computer with same network are connecting internet and axis that. So it can be issue with your moderm or router.
May 08, 2017 | Internet Computers & Internet
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
If my computer does not have internet can i still connect to netflix
Can your computer connect to the internet? If it can, it just means that you have a wired internet connection and not a wifi connection on the computer, which means your iPad is just connected to your home network via wifi. If your computer can't access the internet or you know you don't have internet service at home, then you either have cellular service (3G/4G) or your iPad is connected to some other available WiFi from someone else's service.
Aug 15, 2014 | Apple iPad Tablets & eReaders
I think i hve the router hooked up wrong how do i fix it
Connecting Multiple Computers
thru a router to internet
Tips on choosing the right network can be found at http://www.microsoft.com/windowsxp/using/networking/setup/install.mspx
Since you said there are other computer in the house I assume they will all
go thru the router. I also assume you are using ethernet to connect the new
computer so it will be a "wired" connection. A rounter can also have wireless
connections if the other computers have wireless internet on the other
computers.
To connect more than one computer to the Internet, you need a router.
A router allows you to connect several computers to each other and to the
Internet. The router sits between your computers and the modem provided by your
ISP. You connect the router to the modem, and then connect all your computers to
the router.
To connect a router and multiple computers to the
Internet
Contact an Internet service provider (ISP) and have them configure
an Internet connection to your home. If possible, have the ISP place the modem
in the room with your primary computer.
Connect your router to your modem in one of the two following
ways:
If you currently have a computer connected directly to your
modem:
Unplug the network cable from the back of your computer, and
plug it into the port labeled Internet, WAN,
or WLAN on the back of your router.
If you don't currently have your computer connected to the
Internet:
Plug one end of a network cable (included with your router)
into your modem, and the other end of the network cable into the
Internet, WAN, or WLAN port
on your router.
Plug in your router. After a minute or two, the Internet, WAN, or WLAN light
on your router should light up, indicating that it has successfully connected to
your modem.
Determine whether your computer has a network adapter, and add one if
necessary. Instructions to determine if you have a network adaptor or to install
a Network adaptor can be found at http://www.microsoft.com/windowsxp/using/networking/setup/netadapter.mspx
Shut down your computer by clicking Start and then clicking
Turn Off Computer. Then click Turn Off.
Connect the network cable to your computer's network adapter.
Connect the other end of the network cable to your network equipment.
Start your computer and log on to Windows. Windows automatically detects that
you are connected to the Internet.
Repeat steps 6, 7, and 8 for each one of your computers. If you have a
computer in a different room you can find instructions at http://www.microsoft.com/windowsxp/using/networking/setup/wired.m
Feb 15, 2011 | Zonet ZSR4154WE 80211N Wireless Broadband...
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Jul 22, 2009 | Computers & Internet
How can i use my motorola z3 to connect with the internet
If you mean "how can I connect my computer to the internet using my phone as a modem," then this is possible. Just set up an internet connection from your computer to go through your phone (works wirelessly, I've never tried with USB), and make sure you have a Data Plan on your phone. Connect to the internet with your phone and then use it like Wi-Fi. Keep in mind this will be much slower than using an internet card or any other sort of wireless connection to the internet.
As for getting internet on your phone through your computer, I'm pretty sure you can't do this. It doesn't make sense to even try. It's redundant. Just download what you need using your computer. Then sync the phone to the computer via bluetooth or USB and transfer whatever files you desire to your phone. There's no need to get the phone directly connected to the internet if you have a computer that can get on the internet.
Jan 26, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Computer interfacing
You have a computer (what manufacturer and model?) connected to a Netgear WGR614 wireless router (please confirm the router manufacturer and model) by wire or wireless?
If the computer is connected wireless is it with a wireless adapter built into the computer or added to the computer?
If it was added to the computer what is the manuracturer's name and model of the add-on device?
Has any other computer ever successfully connected to the internet using your router?
  • If so was the computer connected using a wire, if possible?
  • If so was the computer connected wirelessly?
If no computers were connected successfully to the router please provide the name of your internet service provider?
I also may need to know the city and state you are located in or other information. We probably need to configure the router to attach to your internet service providers equipment
The following are to determine if the internet service providers equipment has been successfully installed and the capabilities of that equipment as it may support connecting your router, if necessary, and your computer to the internet.
Were any computers ever successfully connected to the internet by directly connecting to your internet service providers hardware?
If yes how were they connected
  • USB cable?
  • Ethernet Cable?
  • Wireless?
  • If wireless what is the manufacturer and model of the internet serivce providers hardware providing the wireless service?
Dec 16, 2007 | NetGear WGR614 Wireless Router
Linksys Wireless-G Broadband Router Logo
43 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
