Question about Fisher Paykel EcoSmart GWL15
Getting inside the Fisher-Paykel GWL15 washer
I need to replace the neck ring on the Fisher-Paykel GWL15 washer. The old one is excessively worn on one side. Is it easy to open up the top on this washer to replace it? I see two screws in the front, right and left. Is that all there is to it?
    Problem Solver:
  • 15 Answers
THAT'S ALL THERE IS TO IT. VERY SIMPLE
Posted on Apr 07, 2009
    President:
  • Fisher Master
  • 2,651 Answers
Thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Posted on Mar 25, 2008
SOURCE:
How to change the water inlet valve fisher Paykel gwl15
Cut the cable tie off from the thermistor.
So the thermistor sits in the grommet straight.
May 07, 2013 | Fisher and Paykel Washing Machines
Power button on GWL15 has issues
You will need to get a new tac switch installed into the display board
and put some clear packing tape over the crack on the decal to stop water getting in again and wetting the new switch.
Dec 06, 2012 | Fisher Paykel EcoSmart GWL15
GWL15 Fisher & Paykel washer doesn't rinse and spin
see this causes and fix it.God bless you
Lid Switch
This is the most common reason for the washer not spinning or agitating. This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer to access the motor. First you can check the motor windings, to do this remove the plug and connect ohmeter to terminals. Refer to the tech sheet or service manual for the proper reading. Check motor for shorts by connecting ohmeter to terminals and motor housing should have no continuity. Connect voltmeter to motor wire connector and check for voltage. You should have 120 volts, if you do and the motor does not run replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Sep 28, 2012 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer dripping after wash is complete
replace your water inlet valve can order from Repairclinic.com
Mar 01, 2010 | Fisher and Paykel IWL12 Top Load Washer
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
I am getting grey marks on my light colored clothing. I have a Fisher & Paykel topload washer.
THE PROBLEM IS THE AMOUNT OF DETERGENT YOU ARE USING.YOU NEED TO BE USING HE OR HIGH EFFECIENT DETERGENT. THIS MACHINE USES MUCH LESS WATER THAN YOUR VERAGE TOP LOADER.
Apr 07, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Washer leaking water
call fisher paykel they will take care of you chances are the diverter valve is bad they have been having problems with them and make sure your repair people are fisher paykel certified VERY IMPORTANT
Dec 18, 2007 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
298 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
