Question about Dell Inspiron 1525 Laptop
I have a Dell 1525 laptop and when powering up, nothing comes up on the screen but the power light comes on. One time it made a loud beeping nosie.
    New Friend:
No hard drive is ok
Posted on Jan 23, 2014
    Problem Solver:
  • 13 Answers
It depends on the beeping noise you hear. If it beeps short but continuouse then it is probably power problem possibly the battery. You can use a guide to the beeps to determine what exaclty is causing the probpem it might well be the hard drive is gone.
Posted on Apr 29, 2010
My dell inspiron 1525 wont even come on when i press the start button, nothing?
Hi Jerrel Castille,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Now try turning on the computer. If still same issue then check if there are any series of beep codes emitted from the computer and see if there is a Power/ Battery status light glowing near the front (touchpad) of it.
Feb 05, 2015 | Dell Computers & Internet
INSPIRON 1525 NOT STARTING UP
Try taking the battery out then holding the power button down for 30 seconds (this clears the power in the machine), then power back on and hopefully should work.
Apr 15, 2013 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
My Dell Inspiron 1525 just stopped! Won't turn on!
Ok not an issue follow these steps
1. check the ac adapter has a light on it when connected to the laptop and when disconnected from the laptop.
2.If the ac adapter has light then connect it to the system and then press and hold the Fn key present at the bottom left hand corner and then turn on the sytem . Check if there is any light that comes on and then turns off . If it does make a note of it and at the same time check if the sytme beeps , if it does make a note of the interval of beeps
3. if there is no response then you could try removing something called as the memory from ur laptop by flipping the laptop over disconnect the acadapter and battery check for a bay whicj\h reads C/M on it which is the memry bay . U will find memory modules which is green in colour . u just need to move the latch on either sides of it to release it . Try one memory and then turn on the ystem . If this doesnt fix most probably its an issue with the motherboard .
INSPIRON SYSTEM HAVE ISSUE WITH MOTHERBOARD hence try using a different ac adapter amd check the acadapter port for damages .
HOPE IT HAS BEEN INFORMATIVE:)
Mar 31, 2010 | Dell Inspiron 1525 Notebook
My screen is black after powering on. i have
Try an external monitor, if still nothing, power down, remove battery / /tap start button to de energise system / remove / replace ram stick (s).
If stil no go may me mobo / faulty ram(assuming there is NO posting beep) / faulty CPU.
If ext monitor works then prob with monitor itself.
Get moniotr wiring / ribbon plugs checked.
Mar 26, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Laptop Logo
383 people viewed this question
Alun Cox
