Question about GE 32GT740 32" TV
Sound level unstable
Either from the TV control or remote control, no matter what level you set the sound is automatically sets itself to the highest level. You can again turn the sound down but it immediately sets itself to the highest level.
    Scholar:
  • 135 Answers
Hi there!
You may have a button stuck either on the remote or on the TV itself. If this does not solve the problem, you may have to refer to a service technician. The IF Amp or the sound stage may be at fault. Good Luck, Regards, JUS004
Posted on Mar 25, 2008
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
TV sound changes by its self goes to 100 or 0 randomly remote won't work
2 questions.
1. Do any of the remote functions work, IE. channel selector, settings menu etc.?
2. How old is the TV?
Several possibilities come to mind;
The remote battery is low.
The remote sound function may be faulty( bad button switch) this is usually a matter of how much the sound switch is used.
The automatic volume control in the TV has failed. This sounds like the best possibility. Once set, the sound should maintain its level. If not, the the AVC is dead and you will probably have to get the TV assessed by a tech. If this is the problem, you might consider a new TV. Tech service is expensive and in many cases it costs so much to fix a relatively simple problem, that buying a new unit is easier and more economical.
Aug 01, 2014 | Emerson LC320EM9 32 in. LCD HDTV
How do I change my audio setting
It depends on what you want to change about your audio setting. My cable box remote has two audio settings: one for changing the SAP language sound from English, to Spanish or French; and a setting that changes two separate audio functions: one changes the broadcast sound from Dolby Digital (TM) sound to regular stereo sound, and the other will allow using either a fixed setting (cable box sound level is at a fixed level allowing one to use the sound control on the TV, or other audio receiver), or a variable setting (allowing the use of the cable box to adjust the audio level).
My Sony TV control also allows me to adjust the tv's audio treble, bass, balance, and special effect sounds, and if needed, to turn the tv speakers off. Hope this is helpful..................Gary
Apr 23, 2014 | Sanyo DP26640 LCD TV
I have a new LG 47LD500 and the volume changes by itself. I could have the volume set at 25 and after awhile it changes to 11. No matter what sound setting or level at always changes back to standard...
CHECK THE MENU FOR AUTOMATIC SOUND SETTINGS SOME TVS WILL HAVE FEATURES THAT KEEP THE VOLUME AT CERTAIN PLACE OR CHANGE IT TO CERTAIN VOLUME AT TURN ON.
Dec 17, 2010 | LG Televison & Video
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Feb 02, 2018 | Yamaha RX-V596 Receiver
Sound issues?
Yeah, your remote has a volume control under the audio button, turn it up.  --Bob---
Aug 05, 2008 | Philips DVP3960
Bought 2 DTT-9900 converter boxes and hooked them to 2 TV's, get signals after playing around with antenna. but after using both TV's to play a dvd (dvd player hook to TV) The sound went down to almost...
Try turning off the converter box when using the DVD player. The zenith have a second sound control on the converter box remote thus you may have to adjust the sound on the tv remote because you are using the dvr. I set the zenith sound level at the highest level and use on the tv remote only to adjust sound. This eliminated a hiss that the sound control on the converter box was causing.
Apr 28, 2008 | Zenith ZN110 Remote Control
GE 32GT740 32" TV Logo
48 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
