Question about Dell WL6000 Computer Speakers
Speaker Help COnection for DELL
Well i cont figure out where to plug the plugs into on the computer so could you also send my a picture?
    Novelist:
  • 156 Answers
Hi
Check out Dell WL6000 Setup and Quick Reference Guide - https://support.dell.com/support/edocs/acc/P121646/multlang/srg/DAO/srg_dao.pdf
Mike
Posted on Apr 16, 2008
Where do I pug the speakers in ? I need a Picture,Show me the picture.
    • 1 Remove the Dell A215 speakers from the box. Place the speakers in your computer area. The speaker with the volume knob is the right speaker and should sit to the right of your keyboard. Place the other speaker to the left of your keyboard.
    • 2 Plug the left speaker into the right speaker. The left unit has an orange-brown plug that connects to a similarly colored port on the back of the right unit. The other end of the cord is fixed to the rear of the left speaker.
    • 3 Insert the two-prong end of the power adapter into an electrical outlet. Plug the other end into the black power port on the back of the right speaker.
    • 4 Insert the main audio cable into your computer. This cable is fixed to the back of the right speaker and has a green head. Plug the green connector to the green audio-out port on your computer. This port may be on the front or back of desktops or on either side of a laptop.
    • 5 Turn the knob on the right speaker clockwise to turn the speakers on and increase the volume. Turn it counterclockwise to lower the volume partially or all the way to turn the speakers off. The speakers should work automatically on any computer with a sound card.
Let me know if this solved the problem and good luck..
Sep 09, 2011 | Dell A215 Computer Speakers
Do they work with dell computers
Any computer should work with these provided they have a standard 1/4 headphone jack or speaker output on the back of your pc. On a pc the plug inlet has a green ring on it, the microphone goes into pink and Auxiliary Audio input is blue. If they still don't work, make sure they are getting power. If they are powered check to make sure they are fully plugged in to the pc and that it is not muted through your os. There should be an icon next to the clock in the task bar that looks like a speaker. click it and make sure the volume is up and no picture of a speaker with a red / is through it. If the / is showing it means audio is muted. Finally make sure the volume at the bottom right corner of the speakers is turned up. If all else fails try the speakers on different computer with working audio if they work then the other computer has a problem with its sound card, its settings or its driver, if they don't work on it then they may be bad. Let me know if it works or not. We'll figure it out!
Oct 08, 2010 | HP JBL Platinum Computer Speakers
I purchased a dell pc from a neighbor without speakers. I have hp speakers from an older computer and cannot figure out where or how to connect them. there are 3 possible places for speeker jacks, have...
Howdy, the speaker input on a Dell is often on the front and the back. It is usually the green one. The speakers from the HP should have no problem working on the dell; It doesn't care what brand of speaker it uses. Making the actual connection is only part of the deal, the mute could be on or volume turned all the way down.
If the speakers require external power, make sure they are plugged into a good outlet and turned on.
If you check all these things, and still have no sound, let me know and I will help figure out what to do next:)
Regards, Farmerbear at FixYa.com
Sep 15, 2010 | Dell Audio Players & Recorders
How to conect the speaker to the computer? I got the monitor and a friend gave this kind of speaker but I don't find the conection betwen the computer to the screen, have the wire but Ican't find the...
To connect your audio system to your pc do the following:
Step 1. Take the two-pronged cable that plugs into the "Out to PC" and locate the green and pink cables.
Step 2. Plug the green audio end and plug this into the Headphone (line out) jack on your computer.
Step 3. Take the pink audio end and plug this into the MIC jack on your computer.
May 01, 2010 | Boston Acoustics BA745 Computer Speakers
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
Can't figure out where to plug in the transmitter
if the unit your tring to connect has RCA style plugs you can plug them in to the tape REC out connections on the back of the reciever.
Once you turn the reciever on an select your source it will out put on the tape REC out which in turn sends signal to the wireless device.
if the unit your tring to connect has a 1/8" or 1/4" plug you have to convert to RCA or plug into the 1/4" headphone conncetion on the front of the unit
Jul 01, 2009 | Audio Players & Recorders
I had memory added to my pc so everything was unplugged. Now I can't figure out which one is the power source for my speaker bar and where it should be plugged. The speaker bar has the green light on and...
Make sure the green plug from the speaker bar is plugged into the green plug on the back of your computer. If it is plugged into the wrong jack you will not get sound. Hope this helps.
Mar 16, 2009 | Dell AS500 Sound Bar Computer Speakers
Pics from Cyber Shot DSC-W55 Are not loading to Computer.
does the removable drive appear in ''my computer'' ?
when i plug my camera in it doesnt always popup asking you to open to view.
Mar 09, 2009 | Dell Dimension 3000 PC Desktop
I have a two-speaker computer speaker system. The second speaker receives its signal from the first speaker's out/negative terminal. Each speaker has its own power supply. I think that each speaker takes...
well if it's any thing i have seen male end ones small . speakers can take batteries or plug in . hey send me a picture i'll help you out Ricgen09@aol.com.
Mar 03, 2009 | Audio Players & Recorders
My HP Photosmart C5280 All-in-one Printer doesn't seem to be getting the signal from my Dell Inspiron E1705 laptop to print. Can't figure out what I'm doing wrong. Can you please help? Rudy
Can the printer accomplish a self test print?
Have you tried re-seating the USB or re-connecting the printer cable?
Have you tried moving the USB cable to another port on the computer to determine if it is communicating with the computer. When you un-plug, and re-plug you should get a disconnect tone if the laptop is speaker equiped? Do you get this tone?
Nov 19, 2008 | HP Office Equipment & Supplies
Dell WL6000 Computer Speakers Logo
169 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
