Question about Danby DCD5505W Electric Dryer
How do you hook the four wire electric cable to the terminal marked L1, L2, L3? the wires are colored red, white, black and green.
  • 8,197 Answers
To connect power cord:
• Remove the screws from the cover of the
junction box located at the top rear of the dryer.
• Loosen/remove the two screws on the strain
relief clamp and remove from 4-wire supply
cord.
• The strain relief splits into two indentical parts.
• Insert the large flange of both sections into the
hole located on the left side of the junction box
housing. The short flange of both sections and
screws must remain positioned on the external
side of the junction box housing.
• Insert the 4- wire supply cord through both
sections of the strain relief and re-install strain
relief screws, do not fully tighten until electrical
connections are complete.
• Attach the power cord ground conductor (green
wire) to the ground terminal marked with the
ground symbol. Tighten screw until ground
conductor is secure. (See Fig. 7)
• Attach the power cord neutral conductor (white
wire) to the neutral terminal. (marked N)
Tighten screw until neutral conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (black
wire) to the phase terminal (marked L3).
Tighten screw until power conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (red
wire) to the phase terminal (marked L1).
secure.(See Fig. 7)
• Tighten the screws on the strain relief so that
the power cord cannot be moved.
• Re-install the cover of the junction box and
secure with four screws removed earlier.
• The dryer is now ready to be connected to the
power supply receptacle.
This is from the manual for the Danby DCD5505W. You did not give the model # so I went off of what you listed it under.
Good Luck and please rate 4 thumbs for the free answer.
Posted on Apr 29, 2010
  • Danby Master
  • 3,740 Answers
Hi and Welcome to FixYa. I am Kelly. Here is a l;ink with pictures of what it should look like once installed.
http://repair2000.com/cord.html
Black to the left post
White to center post
Red to right post
Green to the chassis ground.
Thanks for using FixYa,
Kelly
Need 120 volt wiring diagram for model 113.299410 table saw with model 824370 motor
L1 L2 are the common or line,cord color doesn't mater, green is ground. also should be the ones with screws. try powering the motor for just a few second 2-3 at the most, if it snaps right to life you got it, if it starts slow or not at all, immediately shut it off and check the wiring again. pictures help us fixya guy help u better. there is thousands of different motors
Jay
Jun 03, 2017 | Pool & Spa
How to connect the power to the dryer
most likely 240volts as most 120 volt dryers are already wired,depending on if its a 3 or 4 wire system depending on local electrical codes,but if its a 3 wire cord,take the RED to terminal L1 and Black to L2 terminal on the dryer terminal board HINT:(the RED and Black can go on either L1 or L2 they are interchangable) ,then the White wire to the N neutral terminal on the dryer terminal board usuall between the L1 and L2 terminal,if theres a Green Wire on the cord this is safety ground and can be attached to any metallic part on the dryer,if its a gray flat cord the 2 outside wires are L1 and L2 the center is Neutral,
so its:
RED=L1 or L2
BLACK=L1 or L2
WHITE=N or Neutral
GREEN=Safety Ground the metal dryer frame
Dec 09, 2012 | Dryers
Need to change to a 4 plug
BLACK TO L1 / RED TO L2 these are your 2 power phase wires and you actually can hook them to either power lug on the terminal strip, then the WHITE wire goes to the NEUTRAL terminal sometimes marked just N usually in between the L1 and L2 terminals, then the GREEN wire goes anywhere on the unit that that connects it to the units case which is the SAFETY GROUND
Apr 12, 2011 | Frigidaire FER641FS Electric Dryer
Which colored wires connect to the dryer?
I'm assuming you're referring to the 220 volt power cord. You should have a red, white, black, and green wire in the cord, or you may have 2 black wires and no red. The terminals on the back of the dryer should be marked with L1, L2, N, and GND (or ground)
Connect the white wire to N.
The black and red (or both black) wires connect to L1 and L2 in no particular order.
The green connects to ground which should simply be a screw in the sheet metal on the back of the dryer.
I hope this helps
Feb 20, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Jan 10, 2011 | Miller Bobcat 3 Phase Welder Generator...
Hi.i got a new dryer and its 3 prong but the house is 4 prong so i got a 4 prong and im not sure where the wires go. The diagram shows L1 N L2 than the green ground but the new 4 prong only has green red...
Ok. Let's simplify this for you. First and foremost you will want to remove the copper strip that goes from your center cord post the to case/cabinet of the dryer. This is to seperate your neutral and grounds within the machine. Some models used a green jumper wire instead of a copper strip but the idea is the same.
Now on the new cord the green (ground) wire is supposed to go to the connection point the copper strip used to go to on the cabinet. The white wire (neautral) is supposed to go to the center terminal connection on the terminal block and the red and black (L1 and L2) wires can go to either of the outside terminals.
The only difference in a four wire cord application is the segregation of the electrical neutral and the ground wires.
Good luck, hope this helps you!
Jun 26, 2010 | Frigidaire GLER341A Electric Dryer
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
The new four prong has a green, white, red, and black wires. The cord we removed is not color coded. Not sure what goes where besides green
red and black wires go to L1 and L2 power terminals and the white wire goes to the N- terminal "neutral" terminal and green is the metal unit case safety ground wire
Jan 30, 2010 | Kenmore Elite 45986 Front Load Washer
Trying to hook up three wire plug, witch wires go where? maytag atlantis mde6400ayw
the red and black go to terminals marked L1 and L2 polarity isnt an issue here,and the white or bare is the N terminal or neutral connection,if its non color coded cord as in gray insulated then the 2 outside conductors are the 2 hot wires L1 & L2 and the center is N neutral
Jan 09, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Install power cord - color sequence . Converting a 3 prong to a four prong power outlet.
a 3 prong has a black/red wire for L1 and L2 hots... then white for neutral- in the four wire setup it will be as follows black L1/red L2 both hot wires, white neutral or "N" terminal and /Green for safety ground to unit case
Sep 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Danby DCD5505W Electric Dryer Logo
391 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
