Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
New motorguide trolling motor stopped working
Put on highest setting and stopped working is there a fuse somewhere on motor? did'nt put one in line when installed.
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
Posted on Jul 15, 2009
SOURCE: Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Posted on Jul 24, 2009
SOURCE: On my standard motorguide trolling motor the
put the motor in the water and ensure that the propeller is at the rear. On the head of the unit (where the direction indicator is) push down and turn the round plastic plate (this plate has the direction indicator on it) clockwise until the direction indicator mark (mine is blue and is about one inch long) is in line with the alignment bar on the non-moveable part on the head. You will hear several "clicks" and this means that the indicator plate is clicking around to the proper directional alignment with the motor in the water.
Posted on Jun 17, 2010
  • 24 Answers
SOURCE: I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Posted on Jun 29, 2010
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
Motorguide trolling motor
The first thing to check,(After making SURE the electricity is disconnected to the trolling-motor) remove the propeller and see if the shear-pin (Usually made of brass) in in place and not sheared/broken.
If it is, your local marine shop should be able to provide a new one. I always carry spares. If the pin is OK, the windings may have an electrical fault that would require a factory-repair.
Sep 05, 2014 | MotorGuide Transom Mount Great White...
My trolling motor stopped working suddenly. It is a 96 motorguide 56. It is completely charged. What else do I check. I check 5 fuses by the battery as well.
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Jun 02, 2011 | MotorGuide FW40 FB 42" 12V FLXMT Trolling...
I have a motorguide fw71 fb bow-mounted trolling motor which I believe is receiving a short somewhere. I have the batteries hooked up right with a 30amp breaker going to each and often when I troll on...
Using an ammeter check for current draw and compare that with specs to determine if your draw is excessive. If motor has ever overheated and some of the windings have had the insulation burn off you will have a motor with less resistance and it will draw more current since less back emf is being generated.. Under those circumstances it can overheat and also blow existing fuses. Should that be the case you are looking at shopping for a new motor.
Apr 18, 2017 | MotorGuide FW71 FB Freshwater Series...
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
New MotorGuide VariMAX trolling motor does not run
May 23, 2009 | MotorGuide Electrical Supplies
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
190 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
