Question about Kohler Fort© Single Lever Handle Kitchen Faucet with Side Spray Polish
Water volume has been getting very slow
For the last two weeks our Kohlar kitchen faucet has been getting slower and slower. Takes about 30 to fill a glass of water. Water pressure is 40 psi plus. Both hot and cold are slow. The screen is clean and has been removed to check flow rate and it remains the same. The faucet has a pull out sprayer on the spout. What are my options?
  • 349 Answers
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Posted on May 03, 2010
Water pressure in kitchen and front shower is weak,and it takes a little bit before the water starts getting warm.I put a new faucet in a couple of weeks ago the type where it has all the pluming in t
When water pressure in more than one place is weak, it means that there is some problems in the water pipe/supply. The chance of having problem in faucet/tap is low. I think you need to get a plumber to check the problem. It may be due to water heater problem or cold water supply problem.
Feb 06, 2014 | Plumbing
HOT AND COLD WATER STOPPED COMING OUT OF OUR KITCHEN FAUCET
Do you get water when you disconnect hose from the faucet? If so, perhaps plastic backflow preventor in the faucet is stuck?
May 29, 2012 | Pegasus Technologies Plumbing
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
Water takes 30 sec to cover 10m from heater to tap
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You are talking about length of time to get hot water from water heater.What diameter pipe are you talking about? What type of faucet do you have?
1/2" pipe has inside diameter of .54" and holds 1.2 gallons per 100 feet
10 meters is 32 feet and holds .4 gallons
Average faucet puts out 2 gallons per minute, so 30 seconds you should get 1 gallon of water.
Put a bucket under faucet and check amount of water flow.
Assuming you draw just hot water from the faucet, then 30 seconds is slow for receiving hot water.
If you have single-handle faucet and raise handle straight up in middle, then you are drawing half hot and half cold, so it would take 30 seconds for hot to arrive.
If hot water is slow, the problem might be crossover.
or low water pressure due to clog in water line
Other problems could include clogged water filter, clogged water softener, defective pressure valve, and low water pressure.
Sources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jul 10, 2011 | Bosch Outdoor Gas Tankless Water Heater...
I have an elkay arezzo faucet, and within the last few months the amount of water that comes out of it has slowed to where it takes 1 minute to fill a 2qt pitcher. Is there something i can do to help it?...
There is probably a filter on the nozzel. This filter needs to be unscrewed, turning it to the left. Once removed the turn the fitting over in your hand and if needed, gently push the filter out. Once it is out you should be able to run it under the water flowing out and it small particles of crud should just wash out. Replace the cartridge, screw the fitting back onto the nozzel, turn on the water and see if the flow improves. Most modern faucets have some sort of screening filter arrangement in the nozzel ends. This is to restrict the flow of water somewhat as a water conservation effort. These screens can clog even if you think your water is clear, over time they are apt to slow the rate of water flow way down. BE SURE the water is turned off when you unscrew and replace the end of the nozzel otherwise you will get quite a bath! Good luck!
Oct 25, 2017 | Elkay Arezzo Single Lever Kitchen Faucet...
Slow water flow
first try and clean the air ratter where the water comes out the faucet it is a screen that un screws off the tip of the faucet. these can get clogged up over time from sediment and particles in the water. if the screen is fine then you can try and replace the supply lines to the faucet if that still doesn't fix it then you will need to replace the faucet because it has clogged up from minerals and particles in the water and there is no way to clean out the inside of the faucet.
May 16, 2010 | Globe Union N58022CP Do it Best 2Handle...
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Mar 01, 2009 | Kohler Coralais Black Single-Control...
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Dec 11, 2008 | American Standard Bath Faucet Ceramix...
Kohler Fort© Single Lever Handle Kitchen Faucet with Side Spray  Polish Logo
345 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
