Question about Sewing Machines
Sewing machine is not stitching properly. What could be the root of the problem? How could I fix this myself
    Genius:
  • 1,116 Answers
Clean and lubricate according to the user's manual.
If this is a newer electronic or computorized model, lubricating has to be done by a sewing machine service tech.
When threading, make sure the presser foot is up as this impacts the seating of the thread into the tension control.
Make sure the needle is installed per the manual - this may be with the flat side facing the back or to the side - again according to the manual for your brand and model.
Check the bobbin to be sure the thread is feeding from spool in the correct direction and through the proper guides, again - the manual.
If you do all the steps and the stitching is loose and gnarly, the machine may need the timing adjusted.
You can give this a try, but you may be better off taking it in for service.
How to adjust the timing can be found at sewusa.com in the repair section.
Posted on Apr 29, 2010
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Singer 6215 Stitch length dial not working properly...have to force knob to turn past 2.5...stitch lengths don't seem to change, either. Thanks!
How long has it been since you've cleaned and oiled your machine?
Your machine requires frequent oiling on the moving metal parts. Most likely the stitch length selector has begun to seize.
SINGER 6214 Manual Page 80
This may help:
Wheel on right side that controls the needle up and down is very tight...
The heated hairdryer may be a good choice to try.
Jan 05, 2016 | Sewing Machines
How to fix decorative stitches for sewing machine.
Make & Model??? Sounds like the stitch selector mechanism is stuck. If it's a mechanical machine, you can try oiling the mechanics of the stitch selector with Tri-Flow Synthetic Oil and then heat with hand-held hair dryer.
Mar 23, 2015 | Sewing Machines
Stitch regulator not working properly
it would be a good idea to have the machine checked, the stitch
length regulator need to be checked to see if it's worn or a gear
that move the part is worn and may need to be replaced.
Oct 23, 2012 | Janome Sewing Machines
This machine will sew properly & then start giving me a loop stitch on the bottom stitch. The top stitch looks good. Have changed tension with the wheel that shows stitch length, etc. This...
you might check your bobbin case tension---turn the screw to the left to tighten----to the right to loosen
also after every project check the needle to make sure it's in good condition
Sep 27, 2010 | Brother LX3125 Sewing Machine
Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
Dec 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
145 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
