Question about Cameras
ISO err won't take photos. Chargable Battery good. Settings at factory default, and we shoot auto only Internal battery?
    Guru:
  • 1,049 Answers
ISO Error is a media error, not related to the battery. It means that either the built in memory or media card is corrupted.
Posted on Apr 29, 2010
Why are my photos washed out when taken outside?
Check that your settings are on auto - to get the best in/out pics
Sep 20, 2014 | Canon PowerShot G3 Digital Camera
Dvr ja7204
Restoring Default Settings
To restore factory default settings to your DVR:
1. Enter the Factory Default menu, by going to Main Menu > Maintenance > Factory Default.
2. Select the OK button to restore factory defaults or select the Cancel button to return to the previous menu.
Note: Network information such as IP address, subnet mask and gateway will not be restored.
hope thid helps. and you can also try removing all power from unit if it does not have inturnal battery. if it does have an internal battery after removing all external power you will have to remove battery to completely reset. Note the latter suggestion will void warrenty if you have to open the unit to remove the battery.
GOOD LUCK :-)
Jun 14, 2014 | Computers & Internet
Photos taken with Olympus MJU 7020 are very grainy. I have tried all different settings but always the photos are grainy. Colours are not accurate either. Very disapointed. The battery also seems to be...
Be sure your ISO is set to a low number like 100. That would help with the noise /grain. White balance is usually the cause for bad color. Try setting wb to auto.
It depends on the shooting format you use. If jpg your computer should be able to read the images. Other formats may be an issue.
Dec 14, 2017 | Cameras
Nikon ISO D100
Sounds like you are set in ISO AUTO. This will change your ISO when you are in light that is low enough to give underexposure. In most of the shooting modes, the D100 will change shutter and/or aperature to prevent underexposure, but if it can't avoid the underexposure, it will change the ISO to correct the underexposure.
It also sounds like you have a low light shooting situation. The blur you see is likely from the long exposure, which is pretty hard to hand hold. Noise in the picture would be from the high ISO, but if it's a noise problem you probably don't have blur.
Avoiding the blur is best done with a tripod or a shutter speed of at most 1/60. If you can't get a good exposure at 1/60 or faster, then try the tripod. If you can't use a tripod, then let the ISO (in auto) go up to 1600 and then remove the noise with photoshop or another photo editor. You'll have to play around with the noise reduction settings to get one that works for you.
The key to low light photos is to make sure you get an exposure that isn't blurred, even if you have to use a high ISO. It's easy to remove the noise in software, but blurry photos can't be fixed.
Oct 11, 2009 | Cameras
Photos taken inside are fuzzy
i think the exposure settings have changed and set to hi if you can get the exposure setting to normal [+/-] to 0 or the shutter has been set to low or the iso has been set to low
but if u are skeptic about going to settings and changing those all important combinations then safest way is to restoring to factory defaults and from there u can keep experimenting again
if there is anything else that you would like to know u can mail me at mail2pvs@gmail.com
happy clicking
Jul 14, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Lens Error and Proper switching on Problem
Same problem for me. Try below one. Its working!!!
Press the power-on button, and at the same time Press and hold the shutter button down
Mar 11, 2009 | Cameras
Not really sure if this is a problem? I have an Olympus E-500 and E-510. When I changes settings on the E-500 (ISO, White Balance, Auto-Focus Mode etc.) it remembers them when I switch it off. The E-510...
If you are shooting in the Auto mode and make the changes when power the camera off it will reset back to factory defaults. If you change the dial to P mode, make those same adjustments and power the camera off and then on again it should maintain those settings. Auto just uses the factory defaulted settings.
Oct 18, 2008 | Olympus Cameras
Black pictures
Check your settings - could be if very black night, and you set it to 100 iso film speed, and maybe you are on say 1/1000 of sec at maybe f16, then that's ok. You would maybe need an explosion in an oil refinery to capture much.
However, you perhaps could try this:
1 change the battery for fresh one, and see if it helps - sometimes, the shutter won't really shut if battery power is very low
2. change the mode setting to auto, and see if the flash pops up and takes a pix - then if the pix is good, the camera is still working
3. Reset the camera to the factory defaults, by:
  • Firstly press the 'menu' button, then the up button above the 'OK' as many times as needed, until you see the top folders are highlighted.
  • Press the right button near the 'OK' until you see the last folder highlighted. You will know this is highlighted when you see the first menu option that says 'Language'. The 3rd one down from that says 'Clear Settings'.
  • Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
  • Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
If that fails, back to Canon! - good luck
Apr 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Hazy photos
I assume you are not shooting into sun. Try shooting with camera in its default settings and mode set to Auto Normal.
Feb 14, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Cameras Logo
83 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
